I got it fixed. What happened was... When i pulled the clicker out to adjust them (first time touching them) apparently there is a washer inside that the bolt goes threw, so when you pull it all the way out the washer falls out. So i had to open 'er up, the primary clutch bolt was NOT tight at all, i was very surprised actually. Got that off, couldnt get the whole clutch out cuz it was hitting the inside of the bellypan, SO, i pulled the govanor out of the shaft and took the three thingys out (things that have a spring between them and ride in a little shaft thingy, haha). Pulled it apart (cleaned it out while i was at it), put the washer BACK in where it belongs, put the (thingys) back together, installed the govanor back in the shaft, bolted it up, fired it up and all seems perfect. Lifted the track and did a couple throttle blips and its working how it should. SOOO, next time i will NOT pull the damn clickers all the way out and drop a washer in the clutch... (Gasp). Turned a 5min job into a good 1.5 hour job or more (never touched the clutches before, but hands on is the best learning experience.)
