Still great fuel as no ETH mandated in that part pf the world!
gtwitch in wyoming
gtwitch in wyoming
gtwitch in wyoming
Before anyone does a reflash, you should first do a cylinder leak down test.
Motor Performance before the reflash...... And performance results after reflash are worthless leak down numbers.
The big problem with reflashes is...... ( we do NOT know the leak down % on the sled Polaris is using for the mapping ).
Are they using a brand new motor ? With 3-1/2% leak down?
Are they using a 500 mile motor ? With 1-1/2% leak down that had a great cylinder finish and rings sealed up nice ?
Are they using a 500 mile motor ? With 7% leak down that has rings that are on their way out the door...... ( basicly junk )
You see if we knew everyone's numbers...... Then we could see who's sleds the reflash works on and if there is a correlation to the leak down numbers.
And there will be........
If you build a map on a sub-par motor the map is basicly worthless to everyone except another guy with the same sub-par motor with the exact same leak down.
If you build a map on a broke in motor with 1-1/2% leak down...... The Map will be awesome for everyone with a good solid top-end with good % numbers.
As I have said...... All the different results are worthless to the masses without leak down numbers
Dan
My God yes...Dan please stop. We get itYou have been busy. Maybe it’s copy and paste
You have been busy. Maybe it’s copy and paste?
