Deleting the stock rad is a waste of time and money. There is no way the bulkhead cooler will make up the cooling needed for this motor.
Did anyone consider they didn't use a tunnel cooler because there is just no room for it? Not sure if anyone has looked in the tunnel and seen the header pipe in there? Lol
"There is no way the bulkhead cooler will make up the cooling needed for this motor. "
As this is how the 2014 M8 is cooled your logic is suspect to me. Makes me want to avoid your products.
Cool down Stingray! NMs statements are well founded. He had a Nytro engined Proclimb before they were ever available from AC or Yamaha. Badmouthing his logic and products is uncalled for. If you compare the bulkhead/tunnel heat exchangers you talk about you will also see that the M8 came with 2 different versions. Even the shorter version is substantially larger than the 7000/Viper version.
Link to 2014 M8000 HCR cooling system. Note the bulkhead/tunnel exchanger. It is larger and NOT the same as a Viper's.
http://www.arcticcatpartshouse.com/oemparts/a/arc/52bde7f0f870021d684c5506/cooling-assembly
That's part of the problem with this site, everyone wants to play armchair quarterback! Anyone who thinks outside the box is criticized for it!
I personally think removing the rad. could help with some of the hot start issues people are having, especially being so close to the air inlet.
Now reversing the fan idea, isn't the best idea out there IMO, but it probably does help when sitting idle. At the same time it seems counter productive at speed with the two air directions fighting each other.
I think if Yami really wanted a tunnel cooler they could have had one VERY easily, the header only takes 8-10" of the first part of the tunnel, but choose to have the weight savings of no ice instead.
And a Hemi needs the same cooling as a Cummins? I think your logic is suspect to everyone."There is no way the bulkhead cooler will make up the cooling needed for this motor. "
The Cat 800 and Yam 1050 are night and day different.
Go ahead and reengineer the cooling system if you like. Makes no diff to me, I just thought I would let people know.
We built 21 Viper turbos last season and one of them had the rad deleted...I will give you one guess as to which one had cooling issues.
it amazes me how when somebody tries to discuss something with you,you have to start insulting people.i always stay out of your threads because this is always what happens,for some reason you take offense to discussion,you would get more respect here if you would talk thing out instead of bashing somebody. NM company that has more hours on the viper testing stuff than every other company out there.mountaintech designs & build some great stuff & are only talking things out with you & making good points.you have some good ideas but really need to learn to take constructive criticism.
First off, the GL1800 radiator fan is programmed to shut off at speeds around 12mph due to not having adequate power to force the air the direction the fan is blowing it. There for it flows through the body work and out the fairing.
Second, a radiator delete might be alright if you tend to ride trails and don't mind running scratchers. For guys in the bottomless pow, whether is 90% of the days they ride or 10%, need the radiator to help keep engine temps down no matter if it's boosted or not.
Third, NM never stated you were a liar. He said your plan will not work, and I see his reasoning. The one he built was boosted, yes. It was running higher temps under the hood and having problems, that's a given. But, I would guess 80% of the viper mtx's out there are getting boost. If not, the ones tinkering with them either A. know what they are doing and have spent countless hours researching trying to figure out what to do to them (which is really just boost) or B. will take it to their dealer who will not do a radiator delete because it will void warranty. I personally have not ridden a viper, and have never met NM, but following what they build and seeing videos of their products, they know what they are doing to the sleds and is backed by hours of their own r&d.
And finally, please stop comparing a viper to the M8000. Yes they may handle similar, but the way a 4 stroke works compared to a 2 stroke is like NM's comparison on a Hemi vs. a Cummins. There is nothing in common besides the frame surrounding them.
