Finally got a vipec to hook up to my pro
Burned two up previously using a lithium ion jump pack
Bryce is too busy with his own stuff but there should be plenty of you guys to help here I hope
This third one is used and had been set up for a different style kit
I actually got this one to start and idle so that's five thousand steps in the right direction
I have no idea how to adjust numbers but have figured out how to turn functions on and off.
Decided to gradually throttle it up to watch numbers and it falls on its face at about half throttle
Being the last guys kit had two injectors and mine has four I turned on the auxillary injector function now it doesn't start.
I suppose since his two injectors were big I'm needing to adjust the stock ones down somehow?
The afr I'm using isn't listed in the drop down menu but the menu has a bunch of different tables, do I apply those to adapt to my aem ugeo wideband?
More questions to come I gotta go
