Does anybody have any detailed instructions on how to install a PUSH turbo kit? Thanks, Kevin.
kevin told me there were no instructions only picts
The hose that goes to the fitting you have circled is the coolant line from the throttle body that has the bend molded into it. The hose in the next picture goes to the line from the other side of the throttle body with the supplied barb fitting and to the exposed side of the turbo when looking at it on the sled. Then you have to connect a small line from the rear of the turbo to the top of the oil tank. Hope this makes sense. Your throttle body wil have no coolant running to it when your done. Im not at home or I would put up some pics.
Alright, just to clarify, the two coolant hoses on the throttle bodies are taken off
Then, the one closest to the turbo runs to the fitting I circled.
From the top of the turbo, the coolant hose runs to meet up with the hose coming off the clutch side throttle bodies.
Do I have it right?
