The one issue on the 18 early release
K
Jan 4, 2017
42
20
8
37
The only issue I have found so far! There's no way to adjust the air in front shocks the plastics are in the way of shraider valve no way to get on unless shocks taken out or flipped over to valves on bottom! Anyone else get there's yet and find this issue ?? IMG_0372.jpg
K
Jan 4, 2017
42
20
8
37
And second issue why the F@@@ is cat still using an aluminum bottom gear sleds got 71 miles on it from today what's good gearing for these things since the bottom gear is already showing wear and need to change it before next ride 28902D7D-3565-4A2F-93FA-AD5ABC936506.jpg
RACINSTATION
7,503
3,459
Idaho
At that elevation, I would run 20/49, or 21/49. We have the Hyvo gears on hand and you can use the stock chain. Let me know if you need any help.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
I don't see a problem with the aluminum gear, never heard of one breaking.
Yes they wear faster, adjust the chain tension and you will be fine.
Sent from my SM-G920R4 using Tapatalk
K
Jan 4, 2017
42
20
8
37
takes like 5 mins to drain it and refill. i did mine at 140 miles.
Yes I know it's quick but why not fix the issue the first time taking apart so you don't have shavings floating around and getting into the bearings it's just a piece of mind and you know 100 miles down the trail it's not going to ruin a bearing
sno*jet
2,827
1,298
i see your point but theres a drain plug so no taking apart right.
