G
UPDATE:
200 miles on the TIED and its working well. Zero belt issues. No pulled strings and belt looks new.
I'm running the 71/55 .46 helix and red/black (140/240) spring
Tuning wise, it requires removing primary weight, however it feels much, much faster and smoother on the upshift. On the trail the sled feels like it just wants to go faster and faster. The backshift is smoother and I would say slightly quicker.
Keep in mind my sled is a 2012 M8 SP 153 and I run mainly 8500-9500 ft. I weigh 190 lbs.
First I was running 68 gr Cat weights and Cat Yellow/Green (114/267). A little short on RPM, at 7800-7950 RPM.
Then Dalton adjustble LW weights at 68.2 gr with Yellow/Green = 8100 RPM. Seemed to run well.
Then I got a wild hair and wanted to try something different. After hearing great things about the MDS I tried a set.
Started with same setup in the TEAM and 77.8 grams (4.8 grams in the tip) and Polaris black primary spring (100/340). Liked the engagement(3600-3800 RPM). Sled pulled harder then it ever has, however needs some fine tuning in the powder. Ran perfect on the trail at 8050-8200 RPM. On the longer hills or when I started on hard pack it would flash to 7800 RPM then slowly pull up to 8050 RPM. However, sometimes in deeper snow, when starting out going slow from a roll, it would only flash to 7400-7600 RPM and then pull up to 7800 RPM.
So I put the Black/Purple (160/240) secondary spring in and took 1.6 grams out of the tips. We will see how that works next trip out. Hopefully its closer.
