Does the team come with good assembly instructions
Yes it comes with great instructions. My advice: you will need a spring compressor that allows you to get at the shaft while the spring is compressed to get this snap ring on. I had to modify my all thread rod and washer set up by cutting one wall out of a 3x2in box tube around 8in long and using this piece to push the spider down allowing me to get at the snap ring on the side i cut out. Most importantly you will need a pair of major external snap ring pliers because normal ones will not open the snap ring far enough and you will damage the shaft if they slip off. Other wise align the balance marks "X" and putting the helix in is cake.
MAJOR snap ring pliers !!!
Had my second ride yesterday with the Team Tied. Put 40 miles on in deep, deep powder so I was able to work the clutch pretty good. The clutch did get very hot, but it was not hotter than the 09 and 10 M8's that I was riding with. The belt still looked good after the ride with no pulled cords and no belt dust to speak of. I really like this secondary over the stock one. It is much more consistent and pulls hard everywhere. Track speed is low to mid 40's in the deep powder, which is higher than i got with the stock secondary. I am running the following at 7500-9000 ft elevation and it pulls 8100 +/- 50 in the deep powder:
71-55/.46 helix
red/black secondary spring
cat yellow/green primary spring
Cutler 65-75 adjustable weights with the shortest plug in the tip tightened until it hits the stop and the second shortest plug in the heel tightened until it hits the stop.
Since I put the Team secondary on I have noticed a rattle on the clutch side of my machine that I only hear when putting around at maybe 5-10 MPH. It is not when I decelerate, but when I am just cruising. I can't tell if it is coming from the Team secondary or somewhere else. I thought maybe it was the clutch cover rattling or the clutch fan rubbing on the side panel, but I pulled them off and rode down the trail and could still hear it. Anyone else notice this noise?
White Rad, are they running the same spring in the pro, and can you tighten the secondary spring.
