Anybody have any info on the team secondary for the proclimb?
stock is a copy.unless you are going with the tied.
I never have clutch temps because every infra-red reader I have tried doesn`t really work on the sheaves.
I can hold a hot potato in my hand. Can you?
Seriuosly though, they FEEL good when I check and I have high expectations.
I've had a Team Tied on for a couple of weeks or more.
I'm not going to talk about performance because it would lead to BS.
I will say it feels electric (pick a thumb position and the r's stay the same no matter what terrian is going on under the track) and I immediatly felt-imagined the sled was smoother through the bars.
Initially because I was taking it easy, I thought I was going to be too heavy on the primary set-up (same as I set with the stock secondary) but after riding some and starting to put my thumb into it, all was good for me.
I picked my starting point (73-57/59 .46; red/blk 140/240) because I ran the red/blk in my 153" M-sleds and liked it, this is the set-up for 155" Poos, and a phone call to Team.
I use the 59 side and have't experimented yet because it feels good (I'd really like to say awesome LOL). I ride between 4000 and 6000 but haven't had anything REALLY deep yet.
My primary is set-up with a "only me" set-up of very light spring and MDS weights. So remember apples to apples.
I am a flatlander and have no interest in engaging in arguements or causing contraversy either. I have been testing a variety of different combos with the factory clucthes. Mine is a short track Procross 800. I am fully aware of the differances between the M and Proclimb set ups compared to mine but I would like to add, for what it is worth, that nothing I tried cut down on the heating issues with my sled like installing the tied team. Sanding the set of clutches did alot as the heat is obviously from slippage caused from many things. I would say altough there is merit to the vibration thing after installing the frog skinz vents, sanding the clutches and installing the tied team there is nearly no heat on long back to back pulls. Of course you hill guys really would torture the belt more than I would.
In MY case "so far" I have found a 77/59 .46 and a Blk/red spring works good but it seems a bit much on the bottom and would like a 75 to try but thats all I had. I tried a red/ blue and a red/ black and personally prefered the blk/red.
Like you said overall performance results are there, I do not want to cause a pissing match but on the 800 short track that single change (tied team) made +5 MPH in the differance for me on the top end in 1500 ft. I swear by the tests as well. RPM's were kept the same, time frame (with in 1/2 hr).....everything....I would actually include to you that even when I purposly heat soaked the sled it was still 3mph faster than the stock clutch. I have a Speedwerx pipe I am going to install and set it up now that I have a baseline. Good Sledidng guys.:canada:
Who did you get it from??? What elevations are you riding? Cost?
