Solid Turbos - Kratos Turbo Kit - Matryx/Axys
Solid Turbos
44
58
55
UTAH
Kratos Turbo Kit - ECM Tuned by Torque Link Bikeman Clutch Kit, Upgraded with FIC 84lb.hr Injectors Capable of fueling up to 275hp, Xona Turbo with Ultra High Flow Turbine Wheel, Turbo by-pass. Fasted Spooling Turbo kit on the market, Zero Lag
Timbre
2,504
Southwestern Idaho
Is there really any turbo that has "zero lag"?
Some might have nearly zero turbo lag, some have a ton.
But there isn't an engine out there that can deliver an immediate hit of boost below its boost threshold RPM.
A@ron
165
88
Wisconsin
Agreed. More like minimal lag. The turbski needs rpm/exhaust to spin. Excited to see this kit on snow!
Solid Turbos
44
58
55
UTAH
All turbos have lag but our turbo kit has zero lag. A turbo is like a plug in the charge tube until it spools. We have a reed cage in the charge box that by-passes the turbo eliminating the lag. When the pressure in the charge box equals atmospheric pressure the reeds close. Those reeds are open for less than a second and then the turbo is lit. We have been running this by-pass since 2019.
BigAir
215
Montana
How much? Will you offer an option without the bigger injectors, for guys who aren't looking for huge hp?
Solid Turbos
44
58
55
UTAH
Negative on the injectors. We scale the ECM for the larger injectors, and they do not affect the fuel mileage. The larger injectors allow us to get more fuel into the crank sooner.
Solid Turbos
44
58
55
UTAH
