How are they for reducing heat.
Updates on 2017 helped but belt heat is still an issue.
How much for that setup?
$295 + S&H you and me are in the same boat in Bend no new snow. I was going to ride stock 18 SP vs stock 17 X with updates &HPS can vs stock 17 SP with no updates do comparison vid then install SHR kit & re test. Now I'm just gunna install tomorrow and see how they stack up once the white S**T hits the fan.
So far both the 850s I've raced up hill one 17 & 18 both with HPS cans are dead even once they come out of the hole. Not one sled edging the other out both pulling hard & picking up speed all the way to the top. All 3 riders roughly same weight. Next time up I will swap my sled back to stock ramps and put SHR in the 850 with Hps can see if we can see same gains when combined with HPS can. Yes the ramps are that easy to swap over. Also loving the secondary spring when on and off the throttle in the trees rips your RPM right to 7900-8000 with no over Reving or dead spots everything's working nicely together. My sled is 2018 850 stock exhaust only performance mod is SHR clutch kit.
2018 165 update. Was up in Sicamous first part of this week. BJ's kit was SPOT ON! Flick the flipper, 7900. Back shift was great. This was in deep snow.
Ace
