See the Bikeman Torque Link reflash for the 2020 Alphas and Riots *** Dyno Horsepower ***
kanedog
Undefeated mountain clutching champ of the world.
2,032
1,717
Nice work Joey. I am interested in more over rev hp/tq up to 8600+ rpm. What adjustments can be made on the torque link to help this?
kgra
231
79
British Columbia
Thanks for the Vids. Joey do you offer a higher octane reflash on its own or with any of the hard parts packages that makes more power? Like a 94 octane Instead of 91. Or is it just simpler to put a higher compression head on if want to push that envelope?
joey@bmp
181
359
Oak Park Heights, MN
www.facebook.com
Yes be sure to subscribe to the channel and you will see the future videos I am working on now adding the Pipe and head in stages with the flash
kanedog
2,032
1,717
I request to take it up to 9000rpm on one dyno run.
Octanee
1,037
144
Cranbrook Bc
Curious, do you guys increase the oil pump oiling? Seems like they sip oil and would likely benefit from more oiling.
kanedog
2,032
1,717
If I have to explain why I want to see it, you wouldn’t understand.
joey@bmp
181
359
www.facebook.com
One could in theory decrease the ignition timing and lean out to allow more over rev but that will only get you so far. With electronics you can only go so far beyond the center of the sound wave sweet spot.
Dec 20, 2018
20
18
3
You'll still have the cheap cast piston with the stock rod....even tho you'd allow more rev that would be useless borderline stupid on a stock build unless your testing for engine limits lol....but you know all that...
Octanee
1,037
144
Cranbrook Bc
I will be releasing tunes for 18 & 19 also for stock, Stage 1 (full Exhaust), Stage 2 (full exhaust and head) and Big Bore 900
Will you dyno it as well with the tune and/or the pipe on a 19? though I may be wrong but It appeared like the 19 and 20 made pretty much same hp,
kanedog
2,032
1,717
Thank you for the answer.
joey@bmp
181
359
www.facebook.com
Yes they are similar but the 20 made a bit more and the 20 does not need a Ypipe like the 2019 did. The ECU strategy is completely different on the 20 and much more refined in stock form. The 2020 Fuel and Ignition tables are much higher resolution. Yes I will do a full dyno build on the 2019.
