L
How long does it take to remove and replace the S module on an 08?
You will need to unbolt/ remove the lower a arms. The dismantling process is quite a bit faster than the re-installment. Getting the bolts realigned up can painstaking. A few hours should suffice for the job. If you are looking to strengthen up this S Module, take a look at GripNRipRacing's support braces. Here is the bundle pack:
http://www.gripnripracing.com/index.php?id_product=148&controller=product
4-6 hrs with a shop full of tools depending on skill and experience.
Again, thanks for all the replies.
As of right now, I don't know if they are going to fix the sled or not as it hasn't been torn down to see what if any damage is done. Have been told that there is NO extra money for the GripNRip bracing so again that is not an option for them. I was just trying to see what approximate time it would take to do the change if it's needed for them.
I don't quit understand the "no money for Grip-n-rip braces"? For $150 bucks you can have the complete set. For $115 you could get the Z-Bros skid and s module brace. Seems like cheap insurance to me but if they are not on your menu, then I put this info out for others who may be following this thread.
It's really quite simply, they don't have any extra money.
I appreciate the responses for the question I asked for them about the S model only.
I'm sure that IF anyone is willing to DONATE the bracing to them they would most likely take it.
We have the ability to strap the chassis down and pull the front end straight on most of them. It was pretty common in 08 and 09. but newer sleds pull the same. it can take as little as an hour ($100) or so...
