Roll-Over Valve kits for Viper/XF7000!
MTN_VIPER
442
NW WA St.
fourstrokesolutionsllc.com
We now have ROV kits for the Viper/XF7000! All Viper/XF7000 ROV kits come standard with our ROVCM.
Also a new feature for the Viper/XF7000 kit is the oil pump re-prime mode!
The ROVCM adds features such as auto-shut down protection, oil pump re-prime mode and a much stronger/faster closing shut-off valve! For a detailed description of about the ROVCM please see our high performance ROVCM page at http://fourstrokesolutionsllc.webs.com/highperformancerovcm.com
New ROVCM programming:
With the shut off valve mounted horizontally above the air/oil separator tank, we have developed new ROVCM programming to fully take advantage of this new mounting location. The ROVCMs are now programmed to initially close the shut off valve at 15.6 to 15.7 volts. This increases the valve closing strength by approximately 150% when compared to straight battery voltage and allows the shut off valve to be the strongest and fastest closing roll over valve built to date!
Engine oil pump re-priming mode:
If a XF7000 or a SR Viper snowmobile is laying of its side with engine still running, the oil pump can start to draw air due to the suction port in the oil tank being exposed to air. When this happens the low oil pressure switch may shut down the engine to help protect the engine. During this time the engine oil pump may also have lost its prime. When the rider gets the snowmobile back upright, he or she may find that the engine may not re-start or starts and shuts down within a few seconds due to no oil pressure.
Because all XF7000/SR Viper Four Stroke Solutions LLC Roll-Over Valve kits are equipped with a ROVCM, we have developed programming specifically for the oil pump re-prime feature! During the re-prime modes the ROVCM commands the valve to close, which allows pressure to build in the oil tank and force engine oil to the engine oil pump for re-priming purposes. The ROVCM uses pulse width modulation to regulate the air pressure inside the oil tank to safe levels. During Quick-prime mode the ROVCM regulates the air pressue to 8 to 8.5 psi. During method 2 (cranking re-prime mode) the ROVCM regulates the air pressure to approx 4 psi.
There are two ways to use the Roll-Over Valve to re-prime the oil pump.
Method 1, Using the Quick-prime switch.
To use the Quick-prime switch simply press and hold the Quick-prime switch down while starting the engine. Once the oil pressure light goes out on the gauge, release the Quick-prime switch. You can also press the Quick-prime switch after the engine has started and notice that the oil pressure light is on. In this case it's best to push and hold the Quick-prime switch right away, so that the pump has time to re-prime before the low oil pressure switch shuts the engine down.
Method 2, cranking re-prime mode.
To use the cranking oil pump re-prime feature, simply leave the tether cord pulled and crank the engine over (the engine does not start during cranking re-prime mode) for approx 30 seconds. The ROVCM will command the shut off valve to close and the LED will flash. After cranking the engine over for approx 30 seconds, re-install the tether cord and start the engine.
Link to pricing info http://fourstrokesolutionsllc.webs.com/pricingandhowtoorder.htm
Link for more info http://fourstrokesolutionsllc.webs.com/xf7000srviperrovkits.htm
Link fo rmore pics! http://fourstrokesolutionsllc.webs.com/apps/photos/album?albumid=15277412
Bill
MTN_VIPER
442
NW WA St.
Now with Quick-prime!
We've just added a new feature to the Viper/XF7000 ROV kits, a Quick-prime switch.
Now re-priming the oil pump on a Viper/XF7000 is as simple as pushing a button on the dash and holding it for a few seconds!
If the oil pump has lost it's prime and the oil light is on after a roll-over. Just push and hold the Quick-prime switch and start the engine. The ROV LED will flash letting the rider know that the ROVCM has closed the shut-off valve, then as soon as the oil light goes out release the Quick-prime switch. Normally re-priming will occur in approx 2-3 seconds:thumb:
Bill
throttlecable
372
334
Fruita, CO
MPI TURBO + ROLLOVER VALVE
The MPI turbo kit on the Viper makes for a different installation process. Because of all of the plumbing relocation and changes involved, the oil/air separator is now moved to the opposite side of the sled. Additionally, MPI supplies a breather hose that replaces the airbox vent line which is where the rollover valve connects to. The new breather hose mates right up to the rollover valve while the valve is still mounted directly on top of the air/oil separator. My modifications may differ than others, but the only necessary cutting I did was to open up a hole behind the black air gill to gain enough clearance for the height of the breather hose once connected to the rollover valve. I also removed the back up alarm and mounted the rollover control box on the flat spot on the fuel tank directly below the alarm location. This is a truly high quality tether setup, and installation was straight forward and easy with all of the supplied instructions and mounting hardware. I think the new quick prime feature with flashing led makes the kit an absolute winner, and I highly recommend this setup to any rider who may find themselves upside down or otherwise separated from their sled without intent! Thank You FOUR STROKE SOLUTIONS LLC!
IMG_3672.jpg IMG_3673.jpg IMG_3677.jpg IMG_3678.jpg IMG_3681.jpg IMG_3682.jpg IMG_3648.jpg IMG_3649.jpg
calltrex
187
37
alberta
I was going to mount it to that flat spot to but couldnt get the horn off. It was completly siezed tight. Didnt want to bust it off incase i want it later
MTN_VIPER
442
NW WA St.
Preseason maintenance
Preseason sled maintenance reminder, for those who are running a ROV kits.
I like to add a small amount of Sil-Glide (silicone grease) or dielectric compound to the inside of the rubber tether plug.
It's also a good time to check the shut off valve to see if it needs cleaning. A quick and easy way to test the valve for cleaning, is to touch the valve housing with your fingers. Then with the key on, pull the tether cord and you should be able to feel/hear a light "click" as the valve closes. If it clicks then your good to go. If no click is felt or heard, then the valve may need cleaning.
The cleaning procedures can be found at http://fourstrokesolutionsllc.webs.com/periodicmaintenance.htm
Caution, do not use brake cleaners to clean the valve. Some brake cleaner contains chemicals that can swell the rubber seal inside the valve and damage it.
Also the valve cleaning procedures may be used on both OFT Racing and Yamaha ROV kits as well.
Bill
RACINSTATION
7,503
3,459
Idaho
I'll just chime for guys that don't have one of these......If you ride a four stroke you need one. Get it. Use it. Love it.
Four Stroke Solutions ROV Kits are solid. Easy to install. And the are plug and play with quality connectors and hardware.
MTN_VIPER
442
NW WA St.
I had this question come up from one of my customers and I think that it is worth mentioning.
On Viper/XF/M7000 snowmobiles, if the rider uses the handle bar kill switch the shut the engine down but forgets to shut the key off, there will still be a 123 mili-amp drain on the battery. Because the ignition key is in the "on" position, one of the snowmobile's relays is still being energized but is not passing current. This is a normal condition and it's always best to turn off the engine using the key.
Note: because the gauge display is powered down the rider may not notice that he/she has left the ignition key in the "on" position.
A unique feature of the ROVCM battery voltage monitoring/auto shut down mode, is that it will also power down the snowmobile relay!
If the tether cord is pulled with the key left in the "on" position and the handle bar kill switch is pressed, the battery voltage monitoring/auto shut down feature will shut down both the Roll Over Valve system and the snowmobile relay to drop the battery draw to zero amps!
BigFish BC
I just sent another order off to Gene, so he should be able to get you set up!:thumb:
Bill
CatRpillar
874
723
Wild Rose Country
Aside from being able to remotely engage and disengage the valve, what are the benefits of going with this system over a purely mechanical rollover valve? Is it more positive and repeatable in its operation for instance?
MTN_VIPER
442
NW WA St.
When a mechanical check valve is used in the breather system, usually it is dependent on gravity to function. Mechanical check valves work well in watercraft, because a watercraft is either going to be right side up, or 180 degrees upside down. A snowmobile can be tipped over pretty much at any angle and often times they are tipped at an angle steep enough for oil to leak out. However it may not be a steep enough of an angle to activate a mechanical check valve.
The electric system actually has several functions
The first function is to get the engine shut down as soon as possible. While engine is running, there is positive air pressure escaping out the breather hose. If the sled is tipped on it's side at a steep enough of an angle, oil can flow over to the breather port in the oil tank. Once this happens the positive air flow (from the running engine) can actually pump the oil out of the tank under pressure.
The second function of an electric system is to simultaneously close the shut off valve while shutting down the engine. The shut off valve closes the breather to help prevent oil from escaping.
A third function on Viper/XF/M7000 sleds is the oil pump re-prime mode. Because the re-prime function uses pressure to feed oil to the supply port, it can be used at odd angles once the sled is rubber side down. This means that you don't necessarily have to have the sled on completely level ground for it to function.
The pump re-prime button can come in handy if you are in an area where you don't want to be in (such as stuck on a side of a very steep hill) and need to quickly re-prime the oil pump to get on your way!
To provide consistent and repeatable valve closing under all operating conditions on Viper/XF/M7000 sleds we use a ROVCM control module. Because the shut off valve is effectively about 170% stronger when a ROVCM is used in the circuit, the valve is much more resistant to oil/moisture residue that may accumulate in the breather system. This also reduces maintenance (valve cleaning) and in some cases even eliminates it.:thumb:
Bill
