Ok, so I just switched to Walker Evan air's on my sled (check my sig), and it didnt sag bad before, but after the switch it drops about 6" with NO weight on it at all. Would this be the springs or could it be a bad rear skid shock? Is there a way add tention to the springs, or do they just sit in the two saddles on each end? Not sure if you need to add tension to the springs, but I can pull them out easily by hand...
Anyone got detailed instructions for the fix?
Here are some thoughts...Rob. It's not a good idea to change the location of the rear arm like 94 did. It will also change the function of the shock & the length of travel. Must not be too bad if 94 has already been doing it. Shocks have a max travel limit & if you make a change to the distance of the swing you run the risk of bottoming the shock on a big hit-that could destroy the shock. Or the shock may lose some effectiveness because you have changed the movement points.
The shock does not control sag, only the springs. I assume that the suspension is all "flat" on a floor-if any part is on a block or rise it changes sag in the rear, makes it worse if the front suspension is collapsed. Can't tell in the pictures if the sag is with or without rider-assume rider is on the sled in pic 2. Will also assume that Rob isn't a big boy, 250 or more. If rider is on the sled & Rob is not a big guy then the springs are toast. (Or you have a broken suspension component) All springs take a set & some lose temper-then time for new springs. Going too heavy on rear springs has a negative effect on sled handling & weight transfer. Since the front track shock acts as a fulcrum, jacking up the rear puts the nose down. On the Edge chassis this is not so bad since they needed more ski pressure. But on The IQ, rider foreward sled, it can make the sled ill handling & nose heavy. When you pin the throttle you need some weight transfer to get the nose up, especially in the powder. Another thing on the IQ you are sitting/standing more over the front axle so the riders weight is much less on the rear suspension than on the edge.
The Polaris sleds are designed with sag. The most uniform method is to measure sag at the rear mounting bolt. (Measuring on the bumper is different because as a sled gets longer the rear drop at the bumper is greater.) First-measuring the distance to the floor without a rider, lift the rear of the sled & then let it sag to measure #1. Then get on the sled & jump up and down a few times, then sit in normal riding position & measure again. Polaris says the distance at the rear bumper should be about 5". I go for 4.5" to 5" at the rear suspension bolt.
As a practical matter I run my rear spring in the loose postion until hill climbing (in set up snow)& then crank it all the way up for less weight transfer. That way you have good weight transfer in the powder but no wheelies climbing. On hardpack this can lead to washing out in corners so you may need more rear spring tension, hasn't been an issue with mine. But if you get my drift, I use the rear springs as a suspension tuning tool.
If you determine that you need new springs, I have some. I put a Holz in my 09 so have all front & rear arms, springs, & a bunch of parts. Rear suspension parts retro back to 03 & are lighter on the 08/09 Dragons. I'll sell everything for $100 + $15 shipping, less than the cost of new springs. Picture of parts available.
Good luck,
Ron
