W
Well here is a little story for YA.
I am the guy that had the Turbo 860 project well not any more i now have 800top end on it ans IT still dose not run like it should! Will not build boost 6 lb at 6500feet and at 9000 feet some sled head racing 860 handed my a@# to me every run. Dave even did the 800 install and rode the sled! ( O by the way dave it is not the 860 that will not let your turbo kit work it is YOU)
Well some very cool friend picked the sled up for me (thanks) and delivered it to me in west Yellowstone two weekend ago first rude down the trail the POS oil tank broke off the bottom of the turbo ( nice) I i did some R&D of my own and with the help from SILBER turbos we fixed that ( thanks SILBER).
Well called Dave and still have had NO help from him Jake did give me some things to look for (thanks JAKE) well so it brings me to today tore down the sled and found two things wrong on Bad deigned charge box so I did some More R&D work and cut the neck of the charge box off and welded it in the right angle so it would have a straight shot to the charge tube so it would not blow the coupler off witch will happen!! I jetted it to Jake and josh's spec NOT Daves setting witch was pig rich om bottom end! and now found that my carb boot had a crack it that DAVE NEW about and said it was not the hole way through WELL DAVE IT WAS AND you put back on my sled Thanks
So will put it all back together and see how it runs and if it still will not run
I will let a good turbo shop work on it like jmoore with Turbo Performance have IT!
Thanks Jake and Jmoore and Josh at Turbo Performance for you help so far and as for Dave at R&D Turbo werx i would not let you work on my 5 year olds bike!!! good luck with your Business
Ps i am not a English major!! as you can tell
( O by the way Dave it is not the 860 that will not let your turbo kit work it is YOU)
