Starting with the base MPI turbo kit offered through Yamaha you have options to build 250hp using the original turbo. We installed the intercooler, stronger waste, fuel pump, and 4th injector to achieve these results. All of these parts and be purchased individually to reach your desired results.<O</O
<O
</O
<O</O
The intercooler upgrade kit includes everything you need to make the upgrade: Intercooler, stronger waste gate, Billet blow off valve, hoses, and everything you need to complete the upgrade. The intercooler is a must have when wanting to run anything over 8# of boost. <O</O
MPI part# mtv-1100 $1449.00
<O</O
<O</O
The fuel pump kit is also needed we trying to run over 8# of boost. This pump kit uses a return style with a 1:1 regulator so you have the right fuel pressure at the rail based on boost pressure. <O</O
MPI part #HSK-1168 $319.95 <O</O
<O</O
The 4<SUP>th</SUP> injector kit will deliver extra fuel based on boost pressure. This 4<SUP>th</SUP> injector allows for the stock injectors to remain in place. This is a great way to deliver extra fuel beyond what the factory injectors can deliver. This allows the stock injectors just to do their job. All of our intercooler have the intercooler weldment installed for easy upgrades in the future. <O</O
MPI part #HSK-1169 $449.00<O</O
<O</O
For those that would like to stay on pump gas we offer a thick head gasket and head stud kit. We offer to different thickness based on altitude. The stock head bolt should never be re-used so included in the kit will be a set of high quality ARP studs, washer, and nuts. <O</O
MPI part #HSK-1170 $299.99 6000/ft+<O</O
MPI part #HSK-1171 $299.99 Below 6000/ft<O</O
<O
<O</O
<O</O
<O</O
<O</O
<O</O
