Mountain Cat 600 Float Needle & Seat
sdsnocop
1,441
2,192
Hot Springs, SD
I am having problems finding the proper part number and supplier for the float needle and seat for a 01 Mountain Cat 600 VEV. Any help would be much appreciated.
Idcatman3
MODERATOR: Premium Member
868
Idaho Falls, Idaho
Which number:
Ref# PartInfo
0 1670-115 TM38-B308 Complete Carburetor
1 Body, Mixing - Right
2 6505-591 Screw w/Washer
3 6506-142 Cap, Top
4 6506-034 Gasket
5 6506-137 Cap, Starter Plunger
6 6506-138 Spring, Starter Plunger
7 6506-139 Starter Plunger
8 6506-209 Gasket
9 6506-231 Funnel Assembly
10 6505-980 Screw
11 6506-232 Valve, Throttle CA 3.0
12 6506-260 Jet Needle 9DFH4-60-3
13 6505-552 Washer
14 6505-628 E-Clip
15 6506-055 Plate, Retaining - Jet Needle
16 6506-054 Screw, Machine
17 6506-043 Lever Assembly - Left
17 6506-047 Lever Assembly - Right
18 6506-053 Bushing, Clip
19 6506-040 Clip
20 6506-039 Plate
21 6506-052 Washer
22 6506-051 E-Clip
23 6506-145 Screw, Fuel Mixture
24 6506-076 Cap, Fuel Mixture Screw
25 6506-079 Spring
26 6506-078 Washer
27 6506-080 Washer
28 6506-101 Starter Jet 135
29 6505-047 Pilot Jet 40
30 6506-091 Washer
31 6505-078 Main Jet - 390
32 6506-121 Float Assembly 1.5
33 6505-875 O-Ring
34 6506-037 Screw, Float Arm
35 6506-036 Chamber, Float
35 6506-250 Chamber, Float - Assembly - Left
36 6506-038 Gasket, Float Chamber
37 6506-072 Screw, Machine
38 6506-032 Plug, Drain
39 6505-185 O-Ring, Drain Plug
40 4505-011 O-Ring
41 6506-218 Washer
42 6506-220 Screw, Air
43 6506-217 Spring
sdsnocop
1,441
2,192
Hot Springs, SD
All the parts diagrams I have found on line only show the float needle as an entire assembly with the floats (No. 32) I cannot tell if the needle seat is included. I am just looking for just the float needle and seat.
Idcatman1
125
Ashton, Idaho
I have never seen one of the plastic needle and seats go bad on the flatslide carb except for one wrecked bad enough to break it.
sdsnocop
1,441
2,192
Hot Springs, SD
I have one that leaks. If I do not shut off the fuel I will have 1 cylinder that will be flooded the next morning. I ordered 2 new o rings and have a parts carb coming in case I need to swap out any other parts. A new float needle valve assembly is a little spendy at $80-$90 each.
