I pushed the shaft (pully still attached) out and the bearing right behind the pulley fell out in pieces. My problem is obvious
Which way does the bearing behind the seal come out? towards the seal or away from it? Also the pully has to come off to replace the bearing on the shaft behind it right? it looks to me like that bearing is up against a shoulder on the shaft and has to come off towards the pully.
Im going to try to type this from my smart phone at a wedding so bare with me..
Both bearings come out the same way towards the Mag side of the sled. You are correct in saying that you will need to remove the belt gear in order to get the bearing behind it off. It does rest on a shoulder on the shaft. What I said before I just ment that the gear didnt need to come off in order to get the shaft to come out.
The seal that is on the PTO side towards the exhaust where the impeller bolts to is an Island onto itself the bearings will not come out that way You will see what I mean once you remove the seal.
Make sure that the housing is in good shape too and that the bearings fit some what tight into it. If they are loose or if the shaft is worn and too loose in the bearings then your going to end up with the same problems again.
All of the times I have done this rebuild I have put in all new better quality bearings and a brand new shaft and impeller. One time I had to put on a whole new housing because a bad bearing had worn it and it would not hold the bearing tight enough.
