N
Have a 2017 AXYS Pro RMK 155. Like to get snappy low end.
Which would work better, Kurt gear down kit or clutch kit?
Thanks
Thanks
i have a 19 155 with tki gear down and trs clutching, works awesome. Tony is the man!Have a 2017 AXYS Pro RMK 155. Like to get snappy low end.
Thanks
Thanks
you can pm trs on here, Tony. he's a great guy and very helpful! can set you up with his custom weights, helix, spring and alignment bar in one kit. clutches run so cool with this set up.I run a Kurts gear down on my 18 163. love the feel, it definitely makes a difference. I also had Indy Dan work my clutches over and am using his mountain weights with SLP springs and factory helix. that set up works well for me
What is TRS clutching
Easy answer......Do Both !!
truthfully I would do both or neither.
but I’m also running a turbo so not the economy choice......
Pro gears or wait for Q2 set up and TRS clutching. Boooom she’s a runner!!!!
Good deal - who's it made by? Polaris? Works with stock top gear? Assume you need a longer belt if using same top gear?
Done a search on q2 and can't find anything - what is it? Or, I should say, who's making it and what're the advantages?
