I bought one of the new turbos and it felt way more nose heavy than my 18 with full expert shocks. I swapped the upgraded expert RTS I had, to the turbo to see if it was just aggressive valving in the RTS and found no noticeable improvement in the heavy nose feel.
Talked to a friend that has an expert and he said he’s noticed a lot more heavy front feeling over his 18 so it’s not isolated to the turbo.
On my 18 with expert shocks I was running:
Ski shocks at 1-2
CTS pretty soft and limiter all the way out
RTS right in the middle (12 clicks)
Torsion springs on 5
Sled felt great, loved this setup!
I’ve read a few comments in other threads mentioning this issue, has anyone found a solution or the source of the problem?
I feel like we can rule out shocks since I had all 4 expert shocks on my 18 and didn’t have the issue.
Could it be stiffer torsion springs?
Different suspension mounting?
Is it the adjustable limiter strap?
I’ve been able to somewhat correct/counteract the heavy nose by playing with my shocks, my current config is:
Ski shock preload at 4+
Lots of preload on the CTS
Limiter strap all the way out
RTS at 4 clicks in
Torsion springs on 2-3
This setup helps a lot but it’s still not quite there and running that high of preload on my ski shocks has its own drawbacks.
What have others tried or found?
Ski shocks at 1-2
RTS at 4 clicks in
