I really couldn't tell you. I would expect that the tighter you have it wrapped, the more force you would need in order to make it open up and lower your ratio. My guess would be that it would give you more bottom end which is what you generally want for mountain riding.
My experience with clutching has been trial and error and it's something that you will mess with forever. I haven't found the silver bullet yet, but it seems to work well enough. I'm always adding and removing weight and moving weight around on my primary. I really haven't done much to my secondary other than move it to the 3 and 7 holes. It has a Bender helix on it that came with the sled and I have no idea what the pitch is on it.
I am by no means a clutching guru. I've talked to guys that have raced and know a lot about it, but they usually give me the same advice, to try different things out and see what works for you. I've done a lot of research on totallyamaha as well.
Another thing you might want to look into if you intend to mess with your secondary clutching is a Shockwave secondary adjustable helix. A lot of the Yamaha 4 stroke guys swear by them. It's one of those things that I have wanted to invest in, but never have.
