L
Tried a chip this past weekend off another nytro. It does help. I noticed the chip is just a resistor in parallel to the circuit. Anyone know the resistance of that resistor?
Are you sure it doesn't "trick" you motor into putting LESS gas into the motor? If you are not 100% sure i would suggest you run an A\F gauge. Remember if it sounds too good to be true it probably is. $50 for 15 -20 more HP is IMO to good to be true. I'm not Bashing, I'm just saying be careful. id86I never did look at the name of the chip. was told it was $50 on ebay.
the chip is not going to wreck your motor. pretty sure it just tricks the motor into putting more fuel into the cylinders, because it thinks the air going into the airbox is colder.
does anyone know what resistors are in the chips? or do i have to take a chip apart?
