Going to have a little fun here.
Since the new Axys is weighing in off the crate at 417lbs and with a can will drop to around 403lbs does the cat even have a chance to get to that weight.
Starting at over 460lb crate weight whats it going to take.
The axys is an impressive sled and having ridden my chassis modified 16 cat and a 16 axys the axys has the upper hand straight out of the box.
Add a 3" powerclaw to it and a few small tweaks and its going to take a lot to make the cat a competitive equal. Although I prefer the potential handling characteristics and ease of use of the cat better, it wont come into play without weight loss.
Really the only advantage the cat has at all is the powerclaw and solid engine, compared to the same old poo engine that even with changes will not compare for reliability.
I already know what it take to make the chassis work,
So for now the only thing I want to figure is can the cat hit the 400-410lb mark, whats it going to take in parts and $$$$$.
Lets give it the benefit of the doubt and say its starting at 460lbs (I think its actually 468lb but even starting at 460 if I can hit 400 I don't care) remove all the idler wheels and it washes into the 460 number.
Diamond S can is a solid 17lb loss @ $600
Belt drive is 7lb keeping an oil tank @$900 (needs geared up anyway so that's a plus)
So that is 25lbs right away
Down to 435lbs
Who has real numbers for different hoods, pipes, etc
The fire and ice hood I have is claimed to be a solid 12lb loss keeping the stock wiring and gauge. $1000
down to 423lbs
I've been told adding a slp pipe and y pipe will drop 6lbs but not sure. $800 with controller.
down to 417lbs with added power at a cost of $3300
Even at this point it will be a monster but I want 400lbs
Now is where it gets interesting. Seat, tank, panels, better hood options whats next.
I still think I can design a hood that weighs about 6lbs with better intake but I don't know the exact stock hood weight.
Price and weight loss, lets here it
Don't forget the cost of clutching and shock revalve, need to check with TOMS on that if I stay with the stock skid. The stock valving is absolute garbage!!!!!!!!!!!!!!!!!!!!!!!!!
Down to 435lbs
down to 423lbs
