R
rotax
11 Pro RMK, SLP PP skis.
The ski rubber has been working itself out from under the spindle so I removed the ski bottom from the spindle bracket and took the nut off the bolt.
But the bolt will not budge, wacked it with a hammer and ruined the threads. Tried backing it out with a ratchet, it catches, binds, and then releases, as if its trying to back out, but is jammed up (rusted?) in the bushing?? Sprayed it with some penetrating oil. Could the bolt be bent?
Any suggestions here?
EDIT: I can clearly see the bushing spinning around when I turn the bolt now.. Having a hard time with it still/getting no where. Sounds like bigger hammer and more force is required?
