Holy smokes ! Thats not kinda bent, thats like fell off a trailer and got t-boned by the truck behind you bent. So the rail edges are pretty reasonable, ($40-$50) I would start drilling some rivets and get a new rail edge to replace that one, After you get the no-snows and the rail edge off you should be able to straighten that tunnel out pretty easy. Hows the bracket that the suspension bolts to? While your at it you may want to have a look at the cooler line under there, make sure it isn't about to break, that would be a bad day on the hill. Is there damage to the bulk head? what are you showing us besides the bent up exhaust deflector ? That piece should be easy enough to straighten out, doesn't need to be perfect, just good enough that it isnt blocking the exhaust.
