Air shifter kit
barefooter
147
49
Sherwood Park, AB
So. Been thinking of trying to use an air shifter on a snowbike. (Already have a Rekluse)
Let me explain. 7 years ago I had a disc collapse in my back. Full paralysis on my left leg. No way to operate - damage was too bad. So over the last 7 years, lots or rehab and just bulling through. I am back to 100 movement in my left leg. The only thing I still suffer from is called "drop-foot" - my foot is extremely week to move up. Lots of strength downward. So my upshifts look like a gorilla doing it, I have to pull up the whole leg, not just the foot. (downshifting is fine).
So after blowing a shift in the hillclimb this weekend - started thinking CVT tranny.
Then I remembered the old airshift technology from the 1980's. Bob Hannah and Broc Glover both raced Open bikes with airshift tech back then.
Searched online and there appears to be both airshift and electric shift mechanisms for quads and bikes. Has anyone actually installed or used one. Any advice appreciated.
http://www.pingelonline.com/prodcat/atv-dirtbike-electric-speed-shifters.asp
G
Nov 15, 2015
259
Fargo
The c02 shifters used in drag bikes work awesome but will have problems with freeze up in the cold. I suggest looking at an electric system. And yes it will work and work very well if done right.
Feb 15, 2015
381
91
CO, western slope
Hadn't seen the ones for the quads, but have seen ones sold for street bikes. Shouldn't be too difficult to set up. I had considered building a snow bike from the ground up as just snow, modified frame etc, and this was my choice for shifting since foot position would change a lot in relation to motor, and shifter being inaccessible. Plus in the snow, I really don't want to have to use my feet.
I would love to see you set this up and give us some feedback.
LoudHandle
3,900
2,775
Valdez, AK
If you decide on a Pneumatic based system, try Dry Nitrogen, IMO would be the best choice for actuation.
Dry Nitrogen is what shocks are supposed to be charged with so they don't freeze.
CATSLEDMAN1
2,630
1,207
Missoula, Montana
HD shifter
One of my bussiness partners asked me to help him install an electric button shift on his Harley 4 or 5 years ago. He bought the kit while in Sturgis several years before and needed help on the installation.
Went pretty smooth, took a Sat morning mostly reading directions and wiring. When correctly adjusted it, it made nice smooth shifts so you could ride with your feet on the hiway pegs without having to come back to the pegs to shift. Never tried power shifts, it had an ignition kill on the shift mode to made nice shifts. Should work on most any bike.
4,078
2,798
I agree you will want the driest air possible to prevent freeze ups.
Nitrogen is used in shocks because it is more thermally stable, not to avoid freeze ups. Dry CO2 or normal compressed air should work just as good in this application.
chumbilly1
1,278
245
I have also thought that a button shift would be slick. bada$$ on dragbikes.
mrsnow
206
9
Shifter
If pushin down is no problem why not put a shifter on with front and rear peddles that way you can always push down to shift?
Tahoe54
171
62
A heel shifter does seem the most economical and simplistic. You might need a custom one to fit though. Only issue with the electric one I see if that most snowbikes are already taxed for electrical output.
search
AKdragon700
152
52
Fairbanks, AK
Response
Looks like Translogic has not done or supports any Powershifters for Enduro bikes. Sent a inquiry about a KTM 500 XC-W
"Hi Jerry
Thank you for your enquiry. I’m sorry, we don’t have any experience with this field, we’d have to say you might need to look elsewhere for product on this occasion.
Sorry we couldn’t be of assistance this time.
Thank you.
Kindest Regards
David Bruton
(Product Manager)
Translogic Systems Ltd"
N
Mar 21, 2016
599
213
NW oregon
Since you don't need the rear brake why not convert that lever to shift the bike up so it's right leg down for downshifts and left leg down for up shifts?
Seems like an aircraft push-pull cable and some welding would accomplish this and be reliable.
