I'm starting this thread so we can help the newcomers to the sport put together reliable snow bikes. I made the decision to build a snow bike two seasons ago, after riding a friend of a friend's bike and was hooked instantly. I knew immediately what bike I wanted, as I had already been thinking about buying a big bore enduro for the last few years. I wasn't sure on what kit I wanted or needed, nor was I sure what components were necessary to build a reliable bike. I drive 9hrs each way to ride (Snowy Range Wyoming), so building a reliable turn key bike was of the upmost importance to me. I was the first to build a bike in my group of buddies, so I had nobody to turn to for advice. This forum and it's members were a big help, but I had to sift through tons of threads and decipher through the BS to find useful tips and information. After a lot of research I still felt like I was in the dark and ended up buying some parts that I never used because of the lack of readily available information. It was a pain that I think we need to help others avoid. I'm not into big jumps, ride mostly timber and tend to be fairly aggressive in the trees. I weigh 180 before gear. Before deciding on building a bike, my plan was to buy a new sled and possibly turbo it. With that being said, I didn't shortcut much as far as $ was concerned when building this bike.
I'm going to post my bike with every component and part that is on it, as well as likes and dislikes.
HOPEFULLY OTHERS WILL FOLLOW AND POST THEIR BUILDS ON THIS THREAD AND UPDATE THEIR BUILD LIST AS NEEDED TO HELP NEWCOMERS BUILD BIKES
I'D LIKE TO KEEP THE THREAD CLEAN AND EASY TO FIND INFORMATION ON EACH BUILD, SO PLEASE PRIVATE MESSAGE MEMBERS WITH ANY QUESTIONS AND COMMENTS YOU HAVE ABOUT THEIR BUILDS. KEEP YOUR BAD OPINIONS TO YOURSELF! LET'S KEEP THIS THREAD ON POINT WITHOUT A BUNCH OF COMMENTS, QUOTES ETC AND JUST STICK TO POSTING BIKE BUILDS!
THUMBS UPS ETC. ARE CERTAINLY WELCOME!! HERE WE GO!
Bike is a 2018 Husqvarna FE501 bought new spring of 2018
Fisher modded 9" seat with factory cover (can't say enough about this seat, unbelievably comfortable and tailored to your weight and riding style, should've had a waterproof cover installed, stock cover is not waterproof) seat concepts sells a complete seat for less $, but isn't tailored to YOU
Fastway Adventure Footpegs ( these pegs work great, much larger platform and have very little ice buildup) Selkirk and C3 both make a sweet set of snow bike specific pegs
Rider's Edge Big Boy Shifter Tip (makes shifting much easier with bulky boots) must have in my opinion
Removed all smog equipment
PR2 Tuned Vortex ECU (had a couple issues at first, Jeff @ PR2 got them handled and was easy to deal with) I have a GET ECU as well, but have not ran it yet
FMF 4.1 Titanium Slip On
Ceramic coated head pipe
Loadmouth Intake, snow bike pod with Outerwear prefilter (this was an expensive setup, but works great) stock air filter cage could be used without the filter in conjunction with an outerwear to achieve similar results for far less $$
Left side panel modded with Frogzskin vents (definitely flows more air) I've never had snow buildup in the airbox no matter how deep the POW has been
BestDualSportBikes.com in tank fuel filter, inline fuel filter, tank fitting, fuel rail, grunt exhaust manifold (unsure whether any of these parts made any gains, in tank filter was for reliability only)
Rekluse Radius CX Cutch with upgraded inner hub (Love the Rekluse, makes tree riding much easier) Recommend a tether switch with use of a Rekluse
Boyesen Water Pump
Highwaydirtbikes.com ultimate hand guards with big bolt option and top clamp (excellent protection) C3 makes an excellent hand guard setup as well
Arctva Handlebar Gauntlets
AME electric heated grips (the heated grip and gauntlet combo work excellent together, hands stay toasty with uninsulated gloves) I didn't do coolant heated bars due to the extra plumbing, may change in the future
Antigravity battery with jumper harness routed to air box ( battery goes dead between trips, jump start and 15mins of riding and it’s good to go until the bike sits in the trailer for a few weeks) I carry an Antigravity XP10 power supply battery with me as backup
Trail Tech Voyager Pro GPS with temp sensor in thermostat housing (love this unit) had some flickering issues last season, but think the dock pins wore out, new dock this season
Moto Minded Stout Mount for Voyager Pro ( Works great, but is expensive for what it is)
Acerbis 3.1 Gal Tank (the extra capacity is awesome) have yet to find a good solution to leaking gas through the vent cap when the bike is tipped over
C3 194* Thermostat (Excellent fit, finish and function)
C3 Medium Height Bar Risers (new for this season) will report back but I’m sure they will be a great addition
Arctic Cat magnetic tether (new this season) will report back, I’m sure this will be a great addition as well
Selkirk Engine Armor Kit (kit was expensive, but was worth every penny, adds extra cooling, protection and looks kick *ss, fit and finish is top notch, lower side panels were designed to match ARO kits, I did some trimming to match the Yeti kit, not a big deal at all ) engine blanket would be less costly, but no extra cooling or protection
Bulletproof radiator guards (added radiator protection) not exactly necessary, but adds a little extra insurance when the bike is tipped over
WP 48mm Open chamber forks ( built by Brockstar for this season) will report back
Snow Kit
2016 Yeti 129 (bought used spring of 2018 from a forum member with most of the 2017 updates) I've made more updates since then
Solid Strut (haven't felt the need to spend the $ on a soft strut)
Yeti Can (have used this every ride, always need more gas) there is a weight penalty here, but extra gas is a must for me
Yeti rack
Pelican Air 1485 case bolted to rack(also a weight penalty, but I love this case, it holds food, drinks, tools, goggles and whatever else I may need) shovel attached to the case as well
Maxtrak 2 (I ride the Snowy Range and this track has worked well for me) may upgrade in the future
Fox Floats (they're light and adjustable) haven't seen the need to upgrade to a conventional shock
Upgraded Titanium track shaft and Drivers for this season (original 2016 drivers were junk)
Upgraded 28mm belt and sprockets for this season (never had an issue with the 21mm belt)
2021 Yeti brake upgrade (new this season) will report back
A lot of people have talked badly about the 2016 Yeti kits, but this kit has been a solid and reliable kit for me thus far (knock on wood) I'm very happy with it
I'm running a Timbersled Aro Spindle and Ski with a Deuce Boy Skeg (works great for me) use a Timbersled wheel kit for moving the bike around, it is an excellent wheel kit
Maintenance I change oil on the bike every 2-3 of days of riding, depending on the hours we ride per day. I run Amsoil 0w40 and oem KTM oil filters. I adjust and lube the chain (if necessary) during the oil change. I'm putting a 12:5:1 Wiseco piston in it before this season for maintenance reasons (80hrs on bike) will also check and adjust valves while it's apart (valves were in spec at 40hrs) I also go over the entire kit every other day of riding and retorque all the fasteners, check belt and track tension.
I am very pleased with this bike and setup. It has been a solid and reliable bike so far. I like the torque of the 500, it's great it the real tight trees which is where I prefer to ride. It never sounds strung out like the 450's, but also doesn't carry the higher RPM's the 450's do which equates to a higher track speed. Never the less, the bike rips and will run with all the 450's with ease.
Boyesen Water Pump
Snow Kit
Yeti rack
