I'd like to put my old PC 141" into SnoPro 440 -99 chassis (with 600 EFI -02 engine). Does anybody know if it's possible to put 57mm lug under old ZR chassis? I know I need to remove coolers from top of the tunnel but wil it fit even I put 7 tooth 3" sprockets?
Y're right! I have too much time - to think! Need more snow! ;D
Just remembered - I put many years ago 2" lug under my Cougar 550 -97. Needed to put 8 tooth 2.52" and still it was really tight. And by calculating 8x2.52" is less than 3x7". So you're right - it will not fit. Damn. Need to put some bigger track to that machine so son can drive by my tracks - at least ;D
Ive got a 99 sno pro with a 144x2x15 I just used stock 144 mtn cat rails, and a 2000ish zr/zl/powder special 500efi w/ a 700 D&D big bore. This sled is unstopable, just need 8 tooth drives. I geared mine down too, 19/39 i beleave.
Well, I measured the clearance and decided to try! Got challenger 141"x2.25" track and bought 7 tooth drivers. Seems there's room for the this track. I've not installed it yet so I'm not sure... It SHOULD be good
