I just bought a 98 rmk 700 with 825 miles and this thing is clean got it home rode about 15 min and it over heated I have checked the water pump belt, tried to bleed the system by parking front end up on a snow bank to make sure bleeder srew is the highest point also tried it by making the resivoir the highest point running with the cap off i have replaced the cap the heat exchangers are warm so it seems to be circulating properly i hooked a coolant system pressure tester up to the over flow hose and pressurized the system with cap in the all the closed position it will only hold 4-5 psi with it on the first notch that you have get over it will hold 11-13 psi (the cap was a 13 psi cap) so if figured the tank was bad and went for a spin with the cap in the spot where it seemed to be good an about 20 min into playing around temp light is on again so i stopped opened the hood and at least it is not coming out of the over flow so i closed the hood and the temp light is off now which seems much better than before so my question is did hey have issuses with the tanks?
seems unlikley to me
any suggestion are welcome and appreciated i am starting to get frustrated
