850 Compression numbers
kanedog
3,112
3,873
What are your compression numbers?
Snopro_69
754
230
Saskatchewan
If talking psi per cylinder, not compression ratio. I'm at 125 psi on each at 2100FT on my 2020. Brand spanking, barely has idled yet even.
Indy_500
1,054
465
29
Greenville, WI
And remember. Gauges vary!!! Both the Polaris 800s I’ve owned haven’t been over 115 psi, which is right where all the 600s I’ve owned have been with this gauge also. I wouldn’t be so concerned about the number as I would be that they are the same. Compression doesn’t tell the entire story though. Piston in the pic still had 115 psi (same as other side) on my 16 800ho and ran ok. Last year I also seized up an 04 pro x 600 (my trail burner for at home) I let it cool down broke it free and ran it 50 miles back to the truck. Nikasil was torn off in multiple spots of the cylinder and piston was mangled. Still had 115 psi.
Snopro_69
754
230
Saskatchewan
Put compression tester in. Unplug other spark plug. Hold wide open and pull hard 5 times. That's how I do it.
Big10inch
926
888
As discussed a hundred times on this forum, compression testing is mostly worthless on a sled. You need to do leak down testing to find out how well it is sealing. Bad pistons and good numbers tell the truth, toss the compression tester, upgrade to a leak down tester. Much better way to monitor the health of your engine.
kanedog
3,112
3,873
We are trying to establish a Polaris 850 compression baseline for comparison of sled to sled bigdum10inch. Come on now, pay attention. Chop chop
madmax
3,147
Salt lake city
Also not a bad idea to get a baseline compression on your personal sled and follow there compression numbers throughout the year.
Mar 21, 2009
193
20
Kennewick, Wa
Literally not relevant to my post.
Big10inch
926
888
Well since other peoples compression numbers aren't relevant either... does it matter?
If you need the static compression number, email Polaris, if you are serious about needing it for mods...
Big10inch
926
888
Yes and you have been here long enough to know that 1) you can not compare numbers from one tester to another, 2) from one elevation to another 3) one test procedure from another. Then to top it off somebody proves my point by showing a ruined piston that still showed good compression. How thick can you get?
Big10inch
926
888
I guess it makes sense here in Polaris land. If you monitor compression, no matter how bad it runs, you can say it has good compression... LOL Polaris lives off of you guys, laughing all the way to the bank.
Teth-Air
4,565
2,795
Calgary AB/Nelson BC
www.specified.ca
Correct me if I am wrong but I believe elevation and barometric pressure should have nothing to do with the compression results on the gauge. You are measuring gauge pressure and not absolute pressure here. If there is less air pressure pushing into the cylinder at higher elevation, there is also less external pressure exerted on the Bourdon tube of the compression tester. They cancel each other out and it is a simple multiplier of volumes of air.
