2009 Twisted Race Gas M8 with over 1000 boosted miles in need of some refreshing.
I have a small problem that is getting worse and more frequent so I suspect the stator, temperature sensor, capacitor, reeds or all of the above......
My problem is after casual riding I'll shut down the sled. After a few minutes I will start the sled but it will not leave the line clean without dying no matter how I feather the throttle. I used to be able to feather the throttle and go. After a few attempts it starts to rev up and I can feather the throttle and go. Once running it is almost flawless. In the morning when loading/unloading the sled it does not act up.
At idle my rpm's are 1500 (seems low thus I suspect the stator is failing from turbo heat and electrical load) headlight isn't as bright as 2010 TM8 at idle, fuel pressure is 38-40psi, 9 pounds of boost average, AF is 14.5 to --- so it is lean at idle and 12.2 on a pull. Oil mixed 40:1. Stock M8 reeds.
I have been told that the temperature sensor high temperature reading can activate or even go bad and default the ECU to a safe mode. I am told that this will pull the fuel and make it hard to start. I am of the understanding that I can put a switch in line with the temperature sensor to remedy this. Opening the contact will tell ECU that it is cold resulting in fuel being added acting like a choke thus aiding in starting the sled. Closing the switch enables the sensor signal back to the ECU mapping for the sleds given instrumentation.
I am not seeing any wrench's or flashing check engine lights progressing to solid check engine lights so I'm not sure if my temperatures are hot enough to activate safe mode? Installing a switch is great insurance and may remedy a few related and non related problems. I'd prefer fixing the issues and have the switch for when the temperature has activated safe mode.
Is it true that when safe mode is activated that it pulls fuel on M8's ? On my old Polaris I was sure that safe mode retarded the timing and added fuel. This has been confusing for me I'd just like confirmation on M8's safe mode??
Refresh List;
1.) M1000 reeds stacked with old M8 reeds. Any other good reeds for TM8? OVS reed stops to help prevent chipping. Service once in summer and once in winter.
http://www.snowestonline.com/forum/showthread.php?t=253115
http://www.snowestonline.com/forum/showthread.php?t=255952
2.) Temperature sensor and switch. Any suggestions or upgrades available?
3.) Stator. Even though it hasn't failed yet it will.... Any upgraded stators out there? Last resort and expensive.
http://cgi.ebay.com/ebaymotors/ARCTIC-CAT-M8-EFI-SNO-PRO-STATOR-2007-2008-_W0QQcmdZViewItemQQhashZitem43a458d853QQitemZ290520094803QQptZSnowmobileQ5fPartsQ5fAccessories
http://stores.ebay.com/RMSTATOR
4.) Capacitor. Do they even go bad? To charge I would assume extra stator wear not to mention the heat from the turbo and the capacitors location.
5.) Primary Clutch. What to look for and replace? Known issues??
6.) Secondary Clutch. What to look for and replace? Known issues??
7.) Inline Fuel Filter. How many miles till it should be changed? I'm not finding one, screens on pickups only?
8.) Diamond Drive bearing has been replaced. Service once in summer and once in winter.
9.) ECU has a cover over it to protect it from snow.
10.) Air temp sensor is in split loom and dangling in belly pan section.
11.) Barometric pressure hose pointing to rear in belly pan section.
12.) TPS how often do they fail?
13.) Plugged injector... How to test?
14.) Fuel Controller issues. Any Codes how do you know when?
15.) Check Ground Connections.
http://www.snowestonline.com/forum/showthread.php?t=255480
Only the Y pipe had to be replaced last year, everything else is stock.
No top end work done yet. I've seen a few TM8's with several thousand miles on the pistons and they look good....
What am I missing or what should I consider?
T.I.A.
Refresh List;
T.I.A.
