martin_e_wilson
I'd bolt stock carb on and try it think we have like 55 pilot needle in middle and like 182 main..... ran good our elevation was like 6-7k at high point starting at 4k
Do you have shut off on your carb heat? I had trouble with it getting so warm it was boiling gas in carb and running poorly. After put a valve on so I could shut it down no problems. My runs excellent.
Ordered A shut off valve from Avid waiting for it now! I just removed the heating system until it arrives to see if that would help fix my issues. I am hoping I got it right tonight the snow is coming down and tomorrow should be fun!
Carb heat will be back on her next week! What gearing did you end up with in your chaincase. Right now I am running 16/18 and that seemed to improve the fun of the bike from the 17/17. I have herd I need to flip the 18 tooth to the top sprocket and the 16 to the bottom for my track speed but I am not really sure what im looking for right now haha!
Harder on reeds because it flows way better..... anf normally revs a 1000 to 2000 rpm overrev more .A lot more movement and wear... I have this running on many bikes band I can tell you I replace the reeds every top end. If not almost 9 out of 10 issues will be reeds even if they look fine. I have ran this set up on a yz85..Lectron yz125... Lectron cr500... Smartcarb KTM 300 lectron and smartcarb beta 300.... Smartcarb and this is my experience.The kips is a piece of junk. mine is pretty much gone. i can't see the pics but i know what your talking about already.
The little pins that hold the main flap open wear down end then it hangs too low in your main exhaust port. you have to take it all apart to fix it.
problem number 2 that doesnt help the above is the base gasket is cut out around the aluminum dowels in the bottom of the cylinder that hold that main flap up, so if your gasket is say .01..your main exhaust valve also hangs down that much lower into the exhaust.
the side ones usually over rotate as well. actuate the lever by hand and watch the side barrels turn. they turn to far and open again. if you take the allen head bolt out at the base of the cylinder...the depth of that bolt controls where those barrels stop. so you can get a new bolt, throw in a small ball bearing, shim etc etc to get them to close at the right spot.
the lectron guys are bang on. if youre running their settings then you have a problem somewhere else. and there is no reason that i can see what you guys are calling a metered carb should be any harder on reeds at all
When I rebuilt the top end I noticed the carbon reeds in the boyesen looked pretty solid. I thought I would check them out again just to make sure but everything seems to look fine here!
Back to the 5-2XL Needle set at 2.083 as suggested. I am going to give it a run tomorrow and see what happens!
With the new release of the timbersled I thought why not skag it up. Added the Golden Standard to the front ski. Time to ride!
I am running a 5-3xl with metering rod set at 2.085" is what I run and it works perfect.
