Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 08-13-2018, 06:22 PM
tmgilder tmgilder is offline
Currently: Not set.
Basic Member
tmgilder is an unknown quantity at this point
Default telescopic steering post
looking at a new sled and it has the telescopic steering post. I know this hasnt been a fan for many riders. I have found two solutions for this, one is a part where you cut your existing post and mount a T style bracket to it to where you can then mount a fixed riser. the other option to replace the entire steering post to the fixed unit. Im asking if anyone has tried the first option, and how it held up. its cheaper and less time installing. i dont have much experience with taking the whole sled apart (which is needed to change the entire post out) and dont really want to pay a shop to do it if i dont have too. any advise or experience with these options is appreciated. thanks!
Rate this post: Yes | No
  #2
Old 08-13-2018, 06:28 PM
ndfb35 ndfb35 is online now
Currently: Not set.
ndfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond repute
Default
Taking the sled apart is not as big of a deal as you think. If you buy the fixed post, the directions and steps are pretty straight forward. If it's your first time it might take you an hour, and it would be good practice.
The Following User Says Thank You to ndfb35 For This Useful Post:
tmgilder (08-13-2018)
  #3
Old 08-13-2018, 10:19 PM
Storskogen Storskogen is offline
Currently: Not set.
Storskogen is an unknown quantity at this point
Default
I think the reason why people don't like the adjustable post is that it has to much play and that problem will still be there if you cut it shorter. I use Canada Sledparts bushings, they have less play but when you raise it it the play gets worse. Im always riding with it in the lowest setting (Im 190cm tall). If you ride with it high you might also bend the adjustable post.
M800 -13, Speedwerx full exhaust, PCV. BC WT 660T -06
__________________
M800 Ltd -13, Speedwerx full exhaust, PC V, AC full vented panels
The Following User Says Thank You to Storskogen For This Useful Post:
tmgilder (08-14-2018)
  #4
Old 08-14-2018, 10:15 PM
line8's Avatar
line8 line8 is online now
Currently: Not set.
line8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond repute
Default
I removed it and installed the zbroz T and new bushings.
I did like the adjustability so I bought the Rox adjustable riser and while I was at it, I installed cfr bars. Very much improved. The feel is so much better.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to line8 For This Useful Post:
tmgilder (08-16-2018)
  #5
Old 08-16-2018, 05:58 PM
Vern Vern is offline
Currently: '14 m8 SP 153-hyvos, dmnd-s, anti-stb,
Vern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond repute
Garage
Default
Don't replace it before you ride it just because you've read that people don't like it. Some people enjoy the adjustable post, I'd ride it first and see how you like it.
The Following 2 Users Say Thank You to Vern For This Useful Post:
Frostbite (08-16-2018), tmgilder (08-16-2018)
  #6
Old 08-16-2018, 07:41 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
My biggest complaint with the adjustable post is, how far back the bars are.
Tilt the fixed bar riser forward till it is at 90° to the floor, and the bars are 2.5" forward.
That 2.5" is a huge improvement in riding stance, especially down a whooped trail!
  #7
Old 08-16-2018, 08:58 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
I wouldn't want to go over the bars with that post extended. set how summ8rmk describes, the riser will pivot forward fairly easily if you have an unfortunate.
  #8
Old 08-16-2018, 10:07 PM
Frostbite's Avatar
Frostbite Frostbite is offline
Currently: Dreaming of riding in deep, deep powder!
Frostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond repute
Default
I'm with Vern on this one. I have had the adjustable bars on my 09 M8 (the first year for adjustable bars) and I have them on my 2015 M800 (the last year of adjustable bars) and I have to say I like them.
I ride with them either all the way up or one click down from the top and have for 10 seasons on both sleds with no issues. I do have the AMP bar riser that moves the bars up an inch and an inch and half forward I believe. I ride off trail almost exclusively as well.
So, give the bars a try. I don't think there are that many issues with them unless you jump a lot or really get after it WAY more than a normal guy.
__________________
The Original Frostbite
  #9
Old 08-16-2018, 10:23 PM
summ8rmk's Avatar
Default
Quote:
Thanks,
I forgot about this. This is also a very important.
I replaced handle bars on my 14 because of a gentle roll over. The pivot riser will allow the bars to roll forward instead of folding/ bending.
Also, i never move my adjustable riser.
And on my 09, 14, and second 14.
On super cold days with snow falling, i have had the lock let loose and bars fully extend (ride in second to lowest setting) while bouncing up a steep climb and almost crash because of it.
  #10
Old 08-16-2018, 10:44 PM
line8's Avatar
Currently: Not set.
  #11
Old 08-19-2018, 01:00 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Click Here to Register
  #12
Old 08-19-2018, 10:18 AM
Currently: Not set.
  #13
Old 08-28-2018, 09:17 PM
Clark42's Avatar
Clark42 Clark42 is offline
Currently: Not set.
Clark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond reputeClark42 has a reputation beyond repute
  #14
Old 08-28-2018, 09:37 PM
summ8rmk's Avatar
  #15
Old 08-28-2018, 10:01 PM
Clark42's Avatar
Currently: Not set.
The Following User Says Thank You to Clark42 For This Useful Post:
summ8rmk (08-28-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Arctic Cat Telescopic Steering Post Thread Starter — oldcrow Forum — Handlebars/Risers (Swapmeet) Replies — 0 Last Post — 01-11-2018 08:47 AM
Thread — Arctic Cat Telescopic Steering Post Thread Starter — oldcrow Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 01-10-2018 07:50 PM
Thread — Arctic Cat Telescopic steering post Kit... ? Thread Starter — lasse Forum — Arctic Cat: M Series Replies — 6 Last Post — 03-08-2017 02:37 PM
Thread — Telescopic Steering Post Replacement Thread Starter — RFIRE4 Forum — Arctic Cat: M Series Replies — 5 Last Post — 03-21-2012 10:34 AM
Thread — 09 m8 boss seat/ telescopic steering post for sale Thread Starter — sheffield Forum — Seats (Swapmeet) Replies — 6 Last Post — 10-12-2009 10:11 AM
