Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-18-2018, 08:18 AM
01ZRTCAT 01ZRTCAT is offline
Currently: Waiting for snow
01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute
Default Turbo install???
I have two M's, 2007 M1000 and 2010 M800
I have been wanting to build a turbo sled, I was leaning towards putting a Turbo on the M1000? I see a few Turbo kits out there.
I'm wondering what you guys think as the both machines are older, is the M1000 the right choice? Who's kit should I get? Looking for opinions
Rate this post: Yes | No
  #2
Old 04-18-2018, 12:28 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
IMO i would do the m8 as i have had a Tm1k. the weight of the m1k is the deal killer. now that said if all you are doing is climbing long hills or chutes the m1 is the best as it produces a lot more power at a lot less boost.
the m1 motor will need more maintenance then the m8 and half the life span as the m8.
  #3
Old 04-18-2018, 12:32 PM
Default
Im fully aware of M1000 weight!
The M1000 just sits, as the only reason I thought of it.
Who's Turbo kit would you chose? For the M800
  #4
Old 04-18-2018, 04:41 PM
Currently: Not set.
Garage
Default
how much boost do you want to run.
you might find some used twisted kits or boondockers around. the one on my tm1 was a cpc rg kit. at 10.5 lbs it would swing 94g in a 3 post primary never had the nuts to turn it up to 12.
  #5
Old 04-18-2018, 06:38 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Both motors are very durable for boost. It is the clutching and diamond drive that require more maintenance under boost.
If you want big power, boost the M1000. But you will need to run a race gas mix to full race gas depending on how much boost. No detonation control on that sled and stock it detonated easily if you didn't watch things. Plan on going through primary clutching faster with the M1000 turbo. But they are a beast with boost. Oh, and they have more run ability challenges (deep powder, etc.).
M8 you can find pump gas kits everywhere and they run well on those kits. But it won't be anywhere close to the m1000 with boost for power. You will get more longevity with clutching (way more) and be able to run standard gas. So, this option is less money and more reliable. And it runs all day everyday.
Depends what you want to do...but probably not a great idea to boost an older M1000...brand new m1000s were prone to breaking under boost due to the big power.
  #6
Old 04-19-2018, 04:29 PM
Default
Picked up a OVS Race Gas for the M800
Has about 300 miles on it, looks brand new great deal!
  #7
Old 04-19-2018, 09:29 PM
Currently: Not set.
Garage
Default
Very good choice
  #8
Old 04-19-2018, 10:55 PM
jim jim is offline
Default
Nice! Now make sure the diamond drive bearing is converted to double row (assure correct clearance) and enjoy.
  #9
Old 04-20-2018, 03:41 AM
Default
Quote:
Will Do! I actually have to change the gearing as the Diamond Drive is out of Xfire. What gearing for a Mseries?
  #10
Old 04-20-2018, 11:07 AM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
  #11
Old 04-20-2018, 11:08 AM
Snowmow's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 04-21-2018, 05:52 AM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BD M7 turbo install help Thread Starter — skime699 Forum — Arctic Cat: TURBO Replies — 19 Last Post — 04-09-2013 10:35 PM
Thread — Turbo Performance E-tec Turbo Kit Install Pics Thread Starter — utah_sledder Forum — Ski-Doo: TURBO Replies — 17 Last Post — 12-01-2012 12:20 AM
Thread — turbo install Thread Starter — Here KITTY KITTY Forum — Polaris: TURBO Replies — 0 Last Post — 01-26-2012 08:28 AM
Thread — BD Turbo Install Thread Starter — rmk685 Forum — Polaris: TURBO Replies — 4 Last Post — 12-24-2011 10:28 AM
Thread — Do it yourself: turbo install??????? Thread Starter — WingNutRacing Forum — Yamaha Replies — 13 Last Post — 08-02-2008 04:06 PM
no new posts
