#1
What adjustments do you need to make when going from stock 39 inch front end to an aftermarket (ZBROZ)36 inch front end?
The stabilizer bar comes out. What other things can you adjust? |
#2
you will have to cut out part of your spindle as when the suspesion is fully extended it will limit the steering. simple and easy.
#3
Your going to have to rebuild your shock length-and add the space to shorten the stroke.
Don't know if you have considered The K-Mod 37" front end. ?? Everything is included and no shock spacing is needed-and comes complete with new (shorter) tie rods, and no mods to the stock spindles.... http://www.kmodsnowmobileparts.com/p...nd-for-pro-rmk
__________________
Dealers for: Silber Turbos. GGB Exhaust. TKI. F-N-I. K-Mod. 2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI |
#4
has anyone tried to keep the sway bar?
What about spring changes? |
#5
Not sure if you're working with an axys,pro or older rmk but our kit is adjustable from 36 to 37" still centered on the spindles. Our PRO kit is normally $475 ($320 less than a 37"), on sale now until April 1st for $365. That's a complete kit with steering tie rods. All our 36" kits have a sway bar attachment with the exception of the older arms that had the shoe, or pocket style. Again depending on what year (12-18) you can use stock shocks, and NO grinder needed. They because we use rod ends have a sheer point that in most cases saves the a arm. The website has a utube link on exactly how they work. Thank you
Dan Last edited by alt; 02-28-2018 at 10:07 AM. |
#6
[QUOTE=ecut;4136350]has anyone tried to keep the sway bar?
QUOTE] The K Mod conversion to 37" as posted in the link in my other post above- ..Can be run with OR without the sway bar.
__________________
#7
You going to have some lower A-arms to part with? Need a lower right for the wife's 600 Pro.
#8
![]() Quote:
#9
![]() Quote:
Dan |
The Following User Says Thank You to alt For This Useful Post: | ||
rags319 (03-24-2018) |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — WTB fornt shocks | Thread Starter — Squatch88 | Forum — Suspension/Shocks (Swapmeet) | Replies — 2 | Last Post — 01-14-2014 04:21 PM |
Thread — Z BROS fornt end for M Series | Thread Starter — 052183 | Forum — Suspension/Shocks (Swapmeet) | Replies — 14 | Last Post — 03-05-2010 06:32 PM |
Thread — F/S 06 IQ 440 fornt susp. | Thread Starter — omernikski | Forum — Suspension/Shocks (Swapmeet) | Replies — 3 | Last Post — 02-11-2008 06:47 PM |
Thread — Fox fornt shocks. | Thread Starter — sepeterson | Forum — Suspension/Shocks (Swapmeet) | Replies — 9 | Last Post — 01-27-2008 07:46 PM |
Thread — Wanted fornt shock for 2004 Rev 800X | Thread Starter — travis575 | Forum — Suspension/Shocks (Swapmeet) | Replies — 1 | Last Post — 12-29-2007 03:40 AM |
