Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 12-09-2017, 09:41 PM
omernikski's Avatar
omernikski omernikski is online now
Currently: On Snowest
omernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond repute
Garage
Default Maybe I'm overthinking this
I have a 03 classic 600 I'm working on for the neighbor. She said it ran like crap and wouldn't go over 40. Took it for a ride and it acted like it was running on half choke. Started digging into it and found the vent line from the mag side carb was off. Put the line back on and it will run like a raped ape now on top end but bottom through midrange it's over fueling. Changed the plugs and tried a different coil and completely cleaned the carbs. Both cylinders are at 115 but the mag side piston is soaked. Reeds are good and valves are clean. I'm at a loss here
__________________
Nccco certified
Rate this post: Yes | No
  #2
Old 12-09-2017, 10:28 PM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
needle valve/seat
  #3
Old 12-09-2017, 10:50 PM
omernikski's Avatar
Garage
Default
Will check that tomorrow. Had to pull it out and bring in another sled
__________________
Nccco certified
  #4
Old 12-11-2017, 01:09 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is online now
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Compression for an 800 with new pistons and new rings is about 148 psi. When it gets down to 130 psi, it feels like a 700. 115 seems well into the "need new top end" range.
Snip about 3/8" off of the plug end of the plug wires, and screw the plug back on, to give some improved performance.
  #5
Old 12-18-2017, 04:43 PM
XCRacer440 XCRacer440 is offline
Currently: In for a shitty winter again...
Basic Member
XCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond repute
Default
Try o rings on the floats. Very common problem especially with ethanol in gas. Also try another compression tester and make sure its really 115.
Edit - Also a o rings set is a fraction of the cost of a new needle and seat combo.
  #6
Old 01-10-2018, 12:08 AM
MrIQR MrIQR is online now
Currently: Too many sleds, not enough time
Basic Member
MrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond repute
Default
needs new float orings. clean the pilot jets while youre at it.
  #7
Old 01-15-2018, 12:21 PM
Ox's Avatar
Ox Ox is offline
Currently: New sled and ready to roll!
Ox has disabled reputation
Default
My chum had issues with that tube when it was new.
He installed an SLP loud box and did not know that the tubes from the carbs needed to go into the airbox.
First ride for that was in the Bighorns and we thought that we were fighting a jetting issue. (which I guess we were, but...)
So - I guess I would dbl check both ends of that (those?) hoses.
edit - I s'pose he's got it fixed by now eh?
__________________
Looks like I lost my old post count ... AGAIN....
Hey - it was a good run while it lasted...
Ask me about aftermarket Doo recoils.
Life Insurance
Death Insurance
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
