Upgrade to Premium
Reply
  #1
Old 11-24-2015, 06:35 AM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default 650 not charging anymore
I went to charge my GPS and now it doesn't charge. It used to display the current charge rate when turned off when charging. Now it shows nothing and isn't charging. I plug it in a few times throughout the summer and run through functions.Anyone else have this happen and what was yur fix? Thanks for the help. It's 3 yrs old very little use.
Rate this post: Yes | No
  #2
Old 11-24-2015, 06:59 AM
xpspenziv's Avatar
Default
Battery power is 71% when I first turned it on prior to charging attempt. Pulled batt out and installed multiple times along with cord different plug is ect.
  #3
Old 11-25-2015, 12:01 AM
cableguy cableguy is offline
Currently: Not set.
cableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond repute
Default
mine does this sometimes i think the power connector is finicky with mine
i put some electrical grease/silicone and it helps and it has to sit just right to charge
  #4
Old 11-25-2015, 10:04 AM
Sling-it Sling-it is offline
Currently: Not set.
Basic Member
Sling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond reputeSling-it has a reputation beyond repute
Default
I had a problem with a brand new one doing the same. Plug it in, wouldn't charge at all. New one does. Hope this isn't a problem.
I did learn to turn off the bat saving mode. When you shut it off in this mode, it only shuts the screen off, still using bat. power.
  #5
Old 01-13-2016, 08:06 PM
2Thetopp's Avatar
2Thetopp 2Thetopp is online now
Currently: on Snowest
Location: Everett WA. 4 minutes from work,one hour from the mountains
2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute
Default
Call Garmin, then hook it up to your computer, they'll walk you through an update, if that doesn't work, then get a repair number, send it in, they will replace if still under warranty, they did for me the first time. Second time it cost me $150.00, sent it in they replaced the unit with another. Still cheaper than buying new.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 1100t not charging Thread Starter — ghostrider73 Forum — Arctic Cat: 1100 ProClimb Replies — 9 Last Post — 04-01-2012 09:29 PM
Thread — charging the battery Thread Starter — dwainew Forum — Ski-Doo: ZX Sleds Replies — 1 Last Post — 02-12-2010 06:34 AM
Thread — Battery Charging Thread Starter — extremedesigndave Forum — Polaris: TURBO Replies — 17 Last Post — 01-04-2010 06:36 PM
Thread — Charging problem Thread Starter — Snow Duck Forum — Arctic Cat: M Series Replies — 2 Last Post — 12-07-2009 11:56 PM
no new posts
