Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 01-19-2015, 06:29 PM
sledr4life's Avatar
sledr4life sledr4life is offline
Currently: Not set.
sledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond repute
Default Formula III help
We have a 96 formula III 600 with a weird clutch issue.
The motor was just rebuilt and went through both clutches at the same time. NO broken springs and everything appears to be in good working order.
The problem is the primary clutch engages and operates fine, but when you let off the throttle the clutch hangs up and snaps back rather than releasing smooth.
I have never seen this before and am looking for what might be causing it. It does it while it you are riding it as well.
Any feedback would be greatly appreciated.
m
Rate this post: Yes | No
  #2
Old 01-19-2015, 09:43 PM
PTE800 PTE800 is offline
Currently: Not set.
PTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond repute
Default
Take the primary spring out and reassemble the clutch. Now try to close the clutch. I think you may find that outer sheave bushing is tight. Sometimes the bushing can get "scard" up when clutch is reassembled.
  #3
Old 01-20-2015, 05:08 PM
sledr4life's Avatar
Currently: Not set.
Default
The clutch has been disassembled and cleaned twice.
Any other ideas?
  #4
Old 01-20-2015, 09:49 PM
Currently: Not set.
Default
If it was ok before the dis-assembly then something is out of alignment or a bushings are damaged . Check the governor cup bushing also.
  #5
Old 01-21-2015, 06:09 PM
sledr4life's Avatar
Currently: Not set.
Default
Will check out the bushings.
The sled was bought non running, so we have no idea if the clutch was operating correctly or not prior to purchase.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — ski doo 583 formula-z Thread Starter — chase107 Forum — Ski-Doo: S-2000 and older Replies — 1 Last Post — 10-12-2014 10:14 PM
Thread — formula z help Thread Starter — 1gdsmawd Forum — Ski-Doo: S-2000 and older Replies — 1 Last Post — 09-15-2014 07:00 PM
Thread — formula 1 Thread Starter — kbl6z Forum — Fouled Plug Replies — 22 Last Post — 03-30-2012 11:38 PM
Thread — formula 3 Thread Starter — kjkohlman11 Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 02-13-2010 09:36 PM
Thread — 99 formula z can Thread Starter — polarisguy2 Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 11-06-2008 02:51 PM
no new posts
