New to these Dual Rate Springs. How much spring rate do they need compared to stock? I noticed that the plastic coupler between the springs has a taller sleeve that is suppose to go up into the small spring leaving it not much room to compress before it bottoms the small spring out. I flipped it upside down in this attached picture cause if I flip it the way it is suppose to be, their is literally only like 1/4" gap before it bottoms out the top small spring and transfers to the bigger lower spring. This makes me think that they don't need much tension at all. Anyone use these and what have you learned with them?
