154 19 Alpha Track Speed
Apr 20, 2018
44
8
8
55
Michigan
What Top speed across a flat with 8-10 inches of loose snow would I expect out of a 2019 154 Alpha.
and or hardpack
We all line'm up on the lake even if its deep.
kiliki
13,213
2,398
Nampa, Idaho
Drag racing a mt sled:face-icon-small-sho.LMFAO with the 19/50 gears and the 8T 3.5P drivers your lucky to see anything over 65-70 mph.
1Mike900
996
169
Bellevue, Wa
Remember in the days you used to take a 900 Cat and produce those speeds in about 300+ ft. with a 2" track. Boy times have changed with a 2.6" track +!
A
ak
2,776
723
80 mph at sea level on a 165 on a hard pack lake.
J
jim
635
Boise
I enjoy racing my friend across lakes. You can always tell when they hit about 80MPH...just look for track paddles exiting the back of the tunnel.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Top speed should be about the same as 2014/2015, 2017mtn cat-2019mtn cat.
They all have the same gears and similar driver diameter. Only difference is overdrive.
Expect about 75mph. U may get up to 80mph.
Polaris and ski-doo will have a higher top speed.
Polaris
kanedog
Undefeated mountain clutching champ of the world.
3,107
3,863
Yes. It is geared way too high. I haven't seen a need for a mountain sled to go 55mph.
Sent from my SM-G920W8 using Tapatalk
J
jim
635
Boise
Begs the question though. If full shift out is most efficient and these sleds pull 45mph track speed loaded on a climb...does higher gearing hurt or help?
boondocker97
4,076
2,795
Billings MT
1:1 ratios of diameters the belt is running on both clutches, at full throttle, at your desired loaded condition would be the most ideal. If at that condition you're shifting out further, then gearing up should help get you to that sweet spot. If at that condition you're under shifting then gearing down may help. Entirely depends on available power and load for the conditions the sled is being ridden in. This is all based on the assumption that you're already running at target RPM. My thoughts anyway.
