Found I had an alignment problem. I don't have an alignment bar, so I did it the redneck way. I knew that with the stock secondary I was in alignment, so I took the Team Tied off and set it on a flat surface next to the stock clutch. I set both clutches on the center shaft that contacts the alignment shims and eyeballed the outside edge of the fixed sheave to check alignment. The edge of the fixed sheave on the Team Tied was taller than the stock secondary. I added a .030 shim under the stock secondary and the fixed sheave was then even with the Team Tied fixed sheave. So, Team Tied is .030 inches further from the edge of the center shaft to the edge of the fixed sheave than the stock clutch. On the stock clutch I had two .060 shims installed (.120 total) to get it in alignment. I replaced the two .060 shims with one .090 shim so now I should be back in alignment with the Team Tied.
That should make a difference in both the clutch chatter and heat. So for those of you putting on a Team Tied, make sure you check alignment because it may be slightly different from the stock secondary.
