Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-12-2014, 07:51 PM
jmeier1981 jmeier1981 is offline
Currently: Not set.
Basic Member
jmeier1981 is an unknown quantity at this point
Default BDX power valve delete vs STM power valve system
It seems like me and all my buddies with AC's have had power valve/servo motor problems this year... everytime we go for a ride together someone has a problem that cuts the ride short so Ive been looking at ways to eliminate this problem.
The BDX power valve delete looks to be the cheapest, easiest, and most reliable fix but it appears to be just a fixed insert that doesnt open or close, and I cant wrap my head around how that can work good... it just seems like theres got to be a reason for the vakve to be there and theres got to be a reason for it to open and close at different points so I dont know how a fixed insert could take its place without a major loss of power somewhere in the curve. They have dyno sheets showing an actual power increase and it looks to be an increase across he entire curve could this actually be true does anyone have any experience with this, especially on a 1000 cat???
The STM system sounds like a decent option, taking the servo motor and cables out of the equation but I only know one person that has this and hes only got a couple short rides with it and his stupid sled is still throwing a intermittent ECU-18 code that really hurts performance and makes him really nervous never knowing when it might throw the code and bog down on him. He took it back to the mechanic that installed it and he said he went thru it with a fine tooth comb and called STM and worked with them they say the "chip" is good and wired right so it must be a faulty ECU causing the problems now... but since his sled hasnt ever worked right since the change and hes got very little seat time since the swap he doesnt know how well its working either
Sooo can anyone give me the pros and cons of either of these setups or any good or bad experiences???
Rate this post: Yes | No
  #2
Old 01-12-2014, 08:07 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
there is no comparison..
STMs are in a different league....you maintain the original concept of the valves without the hassles..
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
  #3
Old 01-12-2014, 08:50 PM
Currently: Not set.
Basic Member
Default
Yeah thats what I was thinking but BDX shows dyno sheets before and after and it appears that they increased the hp numbers across the entire curve... seemed to good to be true to me as well and I know that dyno numbers can be messed with I use to work for the company that manufactures the dyno that they used to run there testing. But I guess I was just hoping there was truth to it somehow since it seemed to be the easiest and cheapest fix, especially if there was an actual performance gain
  #4
Old 01-12-2014, 09:35 PM
Default
the bdx valve delete for certain seemed a failure for the 800s as I haven't heard one good review..
I cannot say for certain about the 1000 but it seems that people wrote that they had a bad lower rpm performance with them .But I am not certain if it happened in all cases.
The power valve is great for low end and the STM keeps that advantage and as well you can adjust the opening rpm if you want with different springs on their new piston style
valve.
I know what you mean by wishing the bdx working ok,maybe someone will pipe in with good results for the 1000..??
__________________
  #5
Cartz-snopro Cartz-snopro is offline
Currently: Not set.
Basic Member
Cartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant futureCartz-snopro has a brilliant future
Default
STM all the way. I'll never go back to the cable /servo crap.
  #6
Old 01-12-2014, 10:12 PM
Firecat162 Firecat162 is offline
Currently: Booost!!
Firecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond reputeFirecat162 has a reputation beyond repute
Default
Im running the STM piston style valves on my 2013 BD Turbo and they have been flawless. Lose some weight and keeps it simple.
  #7
Old 01-13-2014, 03:18 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
I have the newer stem valves one has broke already with very few miles on it it broke tight where the threads start on the main shaft. Caring them tomorrow.
__________________
M 1000 modded but no turbo no way Uh well maybe
  #8
Old 01-13-2014, 10:56 AM
Rixster's Avatar
Rixster Rixster is offline
Currently: I love you El Nino
Rixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond repute
Garage
Default
It may help to understand the theory of the power valve and how it works.
Engineers found that a 2 stroke motor made more torque with an exhaust port lower in the cylinder. The trade off is that you make more horse power when the exhaust port is higher in the exhaust port. So, the fix. Bore a oval for the exhaust port, plug the top portion of it with a movable piece. At lower rpm, keep it closed with in turn lowers the exhaust port, at higher rpm open the valve which in turn raises the exhaust port. that way you get the best of both worlds. I have a hard time believing that you would GAIN any power with either of these setups. And i would tend to believe that with the fixed block off valve, you would see no change in the bottom end and lose hp on the top end.
__________________
Custom built sled decks contact me for details
A.K.A."Seth"
06 M7 CPC Dragoncat 1000 162
F350 crewcab
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and Screaming "WOO" What a ride!
KCCO
  #9
Old 01-13-2014, 11:36 AM
kidwoo's Avatar
kidwoo kidwoo is online now
Currently: schmurrently
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default
Yeah that locked in place BDX thing makes no sense to me at all.
I mean every modern 2stroke motor works on the same principle right? RAVE valves and whatever polaris calls them are the same thing aren't they? Just they (and STM) use springs and cat uses cables and a servo?
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
  #10
Old 01-13-2014, 06:39 PM
bigjb bigjb is offline
Currently: Still playing with the jeep
Basic Member
bigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond reputebigjb has a reputation beyond repute
The Following User Says Thank You to bigjb For This Useful Post:
snoprotrack (09-27-2014)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BDX power Valve Delete? Thread Starter — 007 Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 09-06-2013 03:31 PM
Thread — BDX Power Valve Delete Thread Starter — brian_moreau7 Forum — Arctic Cat: TURBO Replies — 10 Last Post — 02-07-2012 05:25 PM
Thread — BDX Power Valve Delete Thread Starter — cles Forum — Arctic Cat: M Series Replies — 23 Last Post — 01-02-2011 02:42 AM
Thread — BDX power valve delete 4 1200 Thread Starter — tavien Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 10-26-2009 01:46 PM
Thread — ? bdx power valve delete install Thread Starter — tntgoose Forum — Arctic Cat Replies — 1 Last Post — 02-14-2009 09:47 PM
no new posts
