I would consider the M1100T versus the ProRMK. Not sure why anyone would take the M800 ovee the ProRMK besides perceived engine reliability. I wouldn't assume the 800s belt problems will be fixed.
reasons i like my cat over a pro rmk
1 proven engine reliability, pull and go, truth being told recently the pro rmks are going down like flys, its being evident its not if its when. they remind me of the older revs, kickass for 800-1200 miles.
2 better suspension, smoother down the trails to the pow
3 stronger rear tunnel and a bumper that will pull a sled or another broken down buddy.
4 you can put spare gas on the back
6 the motors got more hp
7 vertical adjustable steering posts
8 12 volt accessory rail is nice
9 standing rails you can rely on.
10 it isnt as picky with fuels
11 4 spark plugs means you never foul them in over 5k on M's i change them cause i feel bad but never have fouled them.
12 the bogies tied together in the back are strong!
13 some people are getting away with a belt half the price of poos
14 a-arms are cheaper, and easy to change, and you usually only bend the bottom one if you do.
i could keep going???
the 2013 incentives for snow checks are nice from both manufacturers. the cats will be refined from this year and turned out to be a pretty reliable sleds for a first year so it will only get better.
the 2013 poo has a lot of new tech on it, i like it and hope its reliable but worry the heck out of putting the braking 100% reliant on a belt you blow that belt where i ride and your sled could be in 100 peaces with no brakes by the time it gets to the bottom of the 3-4 k ft pulls we do. can you say learn to hockey stop? and will they warranty that belt? they will a chain. how expensive is this belt? will they now require two 200$ belts in your backpack?
im snow checking one or the other too, im thinking this year go cat, next year if the tech proves reliable on the poo and there motor changes prove reliable i would consider the poo, as thats the year cats first starting to build there own motors.(2014)
-Aksnopro
