I would pay extra for the DD module.
The S-module is where the A-arms attach to the frame. This comes with that bracket attached to an aluminum panel as a unit. It is pretty straight forward to replace. Remove belly pan protector, bumper, belly pan, and start drilling out rivets.
The E-module is comprised on the lower aluminum piece on the belly area, along with 2 aluminum honeycomb brackets on either side of the engine compartment. One side supports the engine and mounts, the other side acts as a support. This piece is more difficult to replace, some have removed the engine completely, others have supported the engine and not removed. You will also have to drill out the larger rivets (stavex style) and replace with pan head bolts. You will also need to remove drivers, track, etc., as 4 of the stavex rivets will be located next to the front cooler.
I spoke with Gordy from Ski-Doo this summer regarding the front/back position of the skis, his imput was generally that indicates the S-module has been bent/tweaked. IMO this is hard to see visually. The E-Module brackets are visable by removing the can on one side, and clutch cover on the other.
Hope this helps!
SJ
