OK looking at putting a 3" camo on an axys with stock belt drive.
Can I just put the stock drive axle out of a chain case sled with 3" pitched drivers in a sled with the stock belt drive and run a center punched 3" camo?
If you take the driveshaft out of a chaincase equipped sled, and put it in one that originally had a belt drive, your pickup for your speedo will not work. They are mounted in different locations. Best to press the different drivers on and use your original driveshaft.
Seen it lots....not an issue.Second question will the stock belt drive hold up?
Last weekend 2 pros had the issues that do not exist.
1. A-arm glue let go, less than 400miles on the sled.
2. Quick drive belt broke.
GS6
Many guys have installed the TKI belt drives on their 3" sleds. also if you want to convert a 2.6" sled to 3" then the TKI belt drive will allow gearing down which is what they really need with 3" tracks.
I have not see an AXYS in person, but I think your statement is not accurate. From perusing the online Fiche both the QD and the chain case equipt sleds; the speed sensor is mounted just in front of the Jack shaft on the right side and it reads the holes in the brake disc. Correct?
Since swapping driveshafts does nothing to the jackshaft / brake disk, IMO he would be fine and speedo would continue to function as designed.
For the guys that have installed the 7 tooth extro's how much did u cut off the rail tips? Who's antistab kit did u use?
