so ive got a 2010 m8, it bogs between about 4000 to 4900, seems to be worse when coming off continuous throttle, like cruising down a trail, let off to go around corner and get back on it it will bog/almost die, but it will bog at random somtimes. it started doing this begining of last year after i installed slp pipe set, power comander v, and mds weights and speewerx spring, bdx oil injection delete. before installing this stuff i had bdx intake and slp silencer and there was no bog. this year i installed some boyesen rage cage reeds hoping to help. no luck. so here is my list of mods.
-slp pipe set
-pcv
-bdx intake
-mds weights/speedwerx spring/shift assist
-boyesen rage cage reeds
-oil delete
so ive got this bog, i had a racin station map loaded last year and told him my problem, he revised it and it was a little better, but still some bog, so i posted on here and got some ideas of what to look for. i removed tss, installed new grip heaters and wiring and switches, adjusted the exhaust valves. all with no luck.
last weekend first ride of the year- still bogs seems worse than i remember last year, rememeber i installed rage cage reeds over summer. so i say what the heck and load up an slp map for giggles. bog is terrible after riding today with slp map. so im going to load the racin station map back up but it was bogging last week just not as bad.
what am i missing? seems fuel related but the racin station map isnt adding much fuel? any ideas
-slp pipe set
-pcv
-bdx intake
-oil delete
