Have a 15' T3 with an impulse kit. For some reason it idles great then if I ride it and slowly get into the throttle or keep it steady down the road up to 6500 rpm it sputters and the afr is all over the place from 11.5 to 13. It almost feels like it loading the motor with fuel like crazy. Ive checked reeds, the check valve between the cases. Power valves are closing at idle, checked clutches twice, changed coils, plugs, checked compression (both at 150). I have a new fuel pump coming and tps. Its throwing zero codes.
