2002 xc 700 edge x chaincase
2007dragonman
740
85
South dakota
Hey guys have a buddy that needs a chaincase and gears for a 2002 xc 700 edge x but it has the reverse kit so it has a different chaincase and stuff than the parts lookup shows, any idea how to kit part numbers with the reverse kit? Thank you
X
X2Freeride
1,546
582
Here are all the parts in the 02 Revers chain case.
*EDIT* ok the link wont take you to exactly the right spot. When you click on the link you need to look on the LH side you will see a place to click called (Chain case reverse models). Click on that. A picture of the case with arrows and numbers will pop up on the RH side, on the LH side a break down of all the parts corresponding to what the numbered items point to. That should have all the part numbers you need.
Hope this helps X2.
http://parts.polarisind.com/Assemblies.asp
