I am putting a 04 escape together with a 02 800 motor, I bought everything to put perc on it, changed out flywheels, harness, Etc.. My question is I bought the newer oil pump because I was told that the old ones(02) don't pump backwards and the newer ones do. the new oil pump would bolt right in but the oil line nipples run right into the recoil housing, I have found a couple newer (o4) recoil housings but they look the same as the one I have, the part number on the pump I bought matches a 04 with perc so according to my dealer thats right, but the recoil housings almost have to be different, just curious if any body else has run into this, and what they have done to correct the problem. Thanks Terry
